Little Forty.
This page is dedicated to the Little Forty models.
In it I include the (F), FV, FVP, LM, and LS (The 'F' here is not to be confused with the 'F' of the later Featherweight. To date we have not found an original 'F', they only appear on the engine numbers sheet for the first year, 1949.) March 2007! Mike Williams in Australia has sent me some mobile phone pictures of a 1951 model 'F'!!! They did exist! Better pictures to follow we hope. Now, 2014, we have several and I have one at SOS!
All These models had radically different engine to drive shaft attachment, they were clamped, so should be easy to distinguish apart from the later motors. Sadly virtually none of the major parts are still available, so cannibalizing dead British Seagulls is often the only way to keep these running. When I say running, I do think it worth saying that these motors have now gone beyond there 'Use by' date and I would suggest they are mostly curios now. After all if you break it out there, you are not easily going to be able to repair it!
October 2017. Some hard to get parts are available!
Steel head and base plates, newly made in the correct thickness, limited number available £15.00 a set.
Little Forty thrust bobbins, newly made limited number available. £10.00 a pair.
The following table has been compiled by Jeremy Prince my thanks to him for this.
If you have a Little Forty and wish to add information to the register,
please contact Jeremy using the contact form. Please click the button below (opens a new tab)
Model |
Serial
Number |
Carburettor |
Tiller |
Tank/Fuel
Pipe |
Magneto
(Flywheel) |
Propellor |
Transom
Bracket |
Misc |
Last Known
Location/Date |
Letter prefix |
No. |
Amal or Villiers. (No) Throttle Stop. (No) Hole in Choke Shutter. (No) Hole
in Bowl |
Stub or Tilting Length (inch). Grip 3 long + 6 short Grooves. Grip 6S for later grip with 6 long grooves |
Small Round/ Canted Oval. Looped or ‘U’ metal Fuel Pipe. Plastic Fuel Pipe (Black/Clear). Fuel cap:- Short/Tall
Ears Narrow/ Wide Slot For LS:-Early
3/4" or late 7/16” rad ends. |
Plain or In or For the World
Cover. (Half) Rimless Baseplate Flywheel Date. 3453 Mag |
3 blade 4 blade Clover-leaf For LS gearbox: Number of inlet Holes |
4” depth Plated or Unplated. 5.4” depth Security Bar on Port side. |
Original Decal. For F,
FV&FVP:-1 or 2 piece Champion Plug
Cap. OESL – Original Engine Support Lug. NESL – New Engine Support Lug. CBPH – Clamp Bolt Pump Housing. |
F |
100 |
From documents rescued from BS
by John Williams, this would appear to have been the first engine of this
series and was produced in 1949. |
F |
201 |
Amal* |
S 5 DG3+6 |
SR SENS |
P RB 10/48 3453 mag |
3C |
4”P ‘inside’ |
Small block- 40cc. 2pc Champion
PC. ‘3453’ Mag |
Gloucestershire |
F |
341 |
Amal |
S 5 |
SR |
P RB |
3C |
4”P*’inside |
Small block- 40cc |
Holland |
The 40cc engines have a bore of
approx 38mm with a stroke of approx 35mm. Up to S/No 1080 they have a small
block with ¼” studs. Thereafter the F, FV and FVP have bigger blocks with
5/16” studs and a larger bore of 45mm. They retain the same stroke of approx
35mm to give a capacity of approx 55cc. |
VF |
1065 |
V 7/16TS NHC NHB |
S 5 NS |
SR LFP |
P RB 10/49 |
3C |
Later |
Large Block |
Uxbridge |
F |
1082 |
Amal |
S 5 DG3+6 |
SR SENS |
P RB 3453 mag |
3C |
4”P ‘inside’ |
Large Block Original decal Non webbed crankcase |
Poole |
FV |
1146 |
V |
S 5 DG 3+6 |
SR SENS |
P RB 1/50 |
3C |
4”P |
Guildford |
FV |
1166 |
V 1/2TS |
S 5 |
SR |
P |
3C |
OD-Seagull |
F |
1207 |
Amal |
S 5 DG3+6 |
SR SENS |
P RB 1/49 3453 mag |
3C |
4”P* |
Large Block OD-Seagull. 2pc Champion PC. Non-webbed crankcase. |
Gloucestershire |
VF1325 was the last to be
produced in 1949. F1326 was the first to be
produced in 1950. |
The first and last serial
numbers for each year are my interpretation of the data in the BS documents
which John Williams has placed on the SOS site. |
FV |
1528 |
V |
S |
SR |
On e bay 4/14 |
FV |
1580 |
V7/16NTS NHC NHB |
S 5 NS Grip |
SR LFP |
P RB 1/50 |
3C |
4”P |
Non-webbed crankcase 2 pc Champion PC |
FV |
1585 |
Scrap crankcase assy. Non
webbed |
Cirencester |
FV |
1623T |
On e bay 4/16 |
FV |
1740 |
Walton on the Naze |
FV |
1782 |
V |
S |
SR |
LFP |
3C |
later |
FV |
1786 |
V 7/16TS NHC NHB |
S 5 DG3+6 |
SR LFP SENS |
P RB 12/49 |
3C |
4”P |
OD-Seagull 1 pc Champion PC. Non webbed crankcase |
Gloucestershire |
FV |
1823 |
On e bay 6/18 |
FV |
1867T |
V 7/16TS NHC NHB |
T 10 DG3+6 |
SR* LFP* SENS |
P RB 12/49 |
3C |
4”P |
Webbed crankcase |
Gloucestershire |
FV |
1884T |
T Stub m/c off |
SR LFP* |
Powerhead. Non webbed
crankcase. T font is different |
FV |
1958 |
S |
Non webbed crankcase only -
scrapped |
Gloucestershire |
FV |
2091 |
V ½ NHC HB |
S G 6S |
SR LFP SEWS |
In* RB |
3* |
FV |
2168 |
V 7/16 |
S |
P RB 3/50 |
Corroded crankcase assy Non webbed crankcase |
Gloucestershire |
FV |
2247 |
On e bay 6/18 |
FV |
2265T |
V 1/2TS |
T 10 |
SR |
P |
3C |
ODSeagull |
FV |
2306 |
V 7/16TS NHC NHB |
S 5 |
SR LFP SENS |
P RB 3/50 |
3C |
4”P |
Gloucestershire |
FV |
2380 |
V 7/16TS NHC NHB |
S 5 |
SR LFP SENS |
P RB 5/50 |
3C |
4”P |
Gloucestershire |
FV |
2405T |
FV |
2461 |
V |
SR LFP |
P RB |
3C |
4” |
FV |
2549 |
V |
S Long |
Later PFP |
F/In ? |
4 Later |
Later |
FV |
2682 |
V 7/16TS NHC NHB |
S 5 DG3+6 |
SR LFP SENS |
P RB 7/50 |
3C |
4”P* |
Gloucestershire |
FV |
2700T |
V ½ TS NHC NHB |
T 10 |
CO |
P RB 7/50 |
3C |
4” P |
OD 1 pc Champion PC |
Flintshire |
FV |
2723 |
V |
S |
SR LFP |
P RB |
3C |
4” |
Dismantled |
Ashford |
FV |
2802T |
T |
CO |
On e bay Oct 2013 |
FV |
2821 |
V 7/16TS NHC NHB |
T 10* DG3+6 |
SR LFP SENS |
P RB 7/50 |
3C |
4”P* |
ODSeagull Webbed crankcase |
Gloucestershire |
FV |
2844 |
V NHC |
SR NSFP |
P RB |
3C |
4” P |
NSESL Non webbed crankcase |
FV |
2886 |
V |
S c10 |
SR LFP |
P |
3C |
4”P |
On SOS site |
FV |
2923 |
V |
S NS |
CO |
4”P |
Fife |
FV |
3048 |
V 7/16TS NHC NHB |
S 5 DG3+6 |
SR |
P RB 7/50 |
3C |
4”P |
Gloucestershire |
FV |
3302 |
V 7/16 TS NHC HB |
SENS |
SR LFP SENS |
P RB 8/50 |
3C |
4” P |
FV |
3364 |
V NHC |
S 5 DG3+6 |
SR LFP |
P RB |
3C |
4” P |
2pc Champion PC. Webbed
crankcase |
FV |
3481 |
V 1/2 TS |
S Long |
SR PFP |
P RB |
3C |
4”P |
Non webbed crankcase Previously Champion PC |
FV |
4105 |
V |
S |
SR LFP |
3C |
4”P |
FV |
4123T |
V |
T |
CO LFP |
P |
3 |
Webbed crankcase |
FV |
4163 |
V |
S 5 DG3+6 |
SR LFP SENS |
P HRB 11/50 |
3C |
FV4342 was the last to be
produced in 1950. FV4343 was the first to be
produced in 1951. |
The FVP was introduced at about
this point, FVP5090 being the first one to date, recorded on this list. The
FVP was identical to the FV, except that it had the bigger 10:35 ratio
gearbox with bigger prop, and longer drive and exhaust tubes. Also, probably about
this time, the top crankcase was modified by the addition of a web above the
cast aluminium tiller stub – no doubt to stiffen and thus enhance the
crankcase sealing in that area. |
FV |
4520 |
Australia |
FV |
4807 |
UK |
FV |
5090 |
V 7/16TS |
S 5 |
SR |
P |
3C |
4”P |
OD –Seagull |
FVP |
5131 |
S |
SR |
P |
FV |
5141 |
V 7/16TS NHC NHB |
S 5 DG3+6 |
SR* LFP |
P RB 2/51 |
3C |
4”P |
Webbed crankcase |
Gloucestershire |
FVP |
5215T |
V NHB |
T |
CO |
3C |
Webbed crankcase |
UK |
FVP |
5425 |
V 7/16TS NHC NHB |
S 5 |
P RB |
3C |
4” |
FVP |
5428 |
V 7/16TS NHC NHB |
S 5 |
P RB |
3C |
4” |
Stripped-not complete |
FVP |
5560 |
V 7/16TS NHB NHC |
S 5* |
SR LFP |
P RB |
3C |
P 4” |
Webbed crankcase |
Hertfordshire |
FVP |
5608 |
V 7/16TS NHB |
S 5* |
SR LFP |
P RB |
3C |
P 4” |
Webbed crankcase |
Hertfordshire |
FVP |
5750 |
V 7/16TS NHC NHB |
S 5 No G |
SR LFP SEWS |
P RB 5/51 |
3C |
4”P |
FVP |
5778 |
V 1/2 |
T NS |
SR TEWS |
P RB 1/51 |
Later |
Been restamped EVR Webbed crankcase |
Bristol |
FVP |
5813 |
Webbed crankcase |
Australia |
FVP |
5846 |
S |
P |
OD |
FVP |
5942 |
V NHC |
NS T |
SR SENS |
For RB |
3C |
Webbed crankcase |
Belfast |
FV |
5950 |
S |
Webbed crankcase, Chromed
crankcase support lug surface |
Gloucestershire |
FVP |
5959 |
V TS |
S Long |
SR |
P |
Webbed crankcase. LS internals |
Skye |
FVP |
5964 |
S |
SR |
Chromed crankcase support lug
surface |
On ebay 2/18 |
FVP |
6046 |
V NHC |
S 5 |
CO LFP |
P RB |
3C |
Later |
Maldon |
FVP |
6152 |
V NHC |
T |
CO |
RB |
3C |
Later |
Webbed crankcase |
Fife |
FVP |
6189 |
V NHC HB |
S |
SR LFP |
P RB |
3C |
4”P |
Webbed crankcase Stripped and bits sold |
FVP |
6222 |
V |
S & T |
CO LFP |
Later |
Clutch gearbox |
FVP |
6284 |
Later V |
S NS |
NS Tank |
P RB |
NS 2H |
Later |
On e bay March 2017 |
Goole |
FVP |
6296 |
S |
SR LFP SENS |
P RB |
3C 2H |
4” P |
Brisbane |
FVP |
6304 |
V TS NHC HB |
SR LFP SENS |
P RB |
3C 2H |
FVP |
6317 |
V TS |
S5 |
SR PEP SENS |
P RB |
3C |
4”P |
Ripponden |
FVP |
6343 |
V ½ HB HC |
S long G 6S |
CO LFP TEWS |
P 6/51 |
3C |
4”P |
FV |
6347 |
V |
S Long |
SR |
RB |
4C |
Later? |
On the web |
FV |
6353 |
V 7/16TS* NHC NHB |
S 5* NS Grip |
SR UFP |
P* RB 6/51 |
3C* |
4”P* |
Webbed crankcase |
Gloucestershire |
FV |
6400 |
V 7/16TS |
S 5 |
SR |
P |
3C |
ODSeagull |
FV |
6405 |
V 7/16TS NHC HB |
S5 DG3+6 |
SR LFP SENS |
P RB 7/51 |
8” NS 3C 2H |
4”P |
Webbed crankcase Al impeller FVP prop |
FVP |
6493 |
Integral cast T bracket |
Crankcase assy only. Later LS
size c’case. |
Gloucestershire |
FV |
6569 |
V 1/2TS |
S 5 |
CO |
P |
4C |
ODSeagull |
FV |
6661 |
S |
NS tank |
3C |
On e bay 5/19 |
FV |
6798T |
V |
T |
CO PFP |
3C |
4”P |
You Tube |
FVP |
6842T |
7/51 |
Dorset |
FVP |
6870 |
V |
T |
NS tank? LFP |
RB |
NS gearbox |
4”P |
Champion PC |
New Zealand |
FVP |
7089 |
V HB |
S |
CO SENS |
P RB 8/51 |
3c 2H |
4”P |
OESL |
FVP |
7118 |
New Zealand |
FVP |
7135 |
S5 DG3+6 |
OESL |
FVP |
7383 |
V NS |
S5 |
SR LFP |
RB 9/51 |
3C |
4”P |
OESL Webbed c,case |
Melbourne |
FVP |
7739 |
FVP |
7751 |
V TS NHC NHB |
S 5 |
CO LFP |
P RB 3/51 |
3 |
OESL |
FVP |
7767 |
V TS |
S –T (NS) |
SR LFP |
P RB 11/51 |
3 |
OESL |
FVP |
7837 |
None |
FVP |
7862 |
V NTS |
S 5 NS Grip |
SR LFP SENS |
In RB |
3C |
Later |
OESL Webbed crankcase |
e bay June 2017 |
FVP |
7893 |
V NHC HB |
S 5 |
SR LFP |
P RB |
3C |
4”P |
OESL Later head |
FVP |
7896 |
S 5 |
SR |
RB |
3C |
4” |
OESL |
On e bay 4/19 |
FVP |
8035 |
V 7/16 NHC NHB |
S 5 |
SR LFP |
P RB 10/49 |
3C 2H |
4”P Plastic CR |
OESL 2pc Champion PC Webbed crankcase |
FVP8041 was the last to be
produced in 1951. FVP8042 was the first to be
produced in 1952. |
FVP |
8090 |
V |
NS |
Later |
Later PB |
Later 4”? |
Later |
OESL |
FVP |
8190 |
V |
S Long |
P |
4C |
OESL |
Bury St Edmunds |
FV |
8222 |
V7/16 TS NHC HB |
S 5 |
SR LFP SENS |
In RB |
3C |
4”P |
Notts |
FV |
8250 |
V7/16 NHC NHB |
S 5 DG3+6 |
SR LFP SENS |
P RB 12/51 |
3C 2H |
4” P |
FV |
8297 |
e bay Sept2013 |
FVP |
8369 |
V |
S 5 |
SR UFP |
HRB |
3C 2H |
OESL |
Fife |
FVP |
8582 |
V NHC NHB |
S 5 |
SR |
None |
3C |
None |
OD OESL Webbed crankcase |
Flintshire |
FVP |
88?? |
FV |
8905 |
V |
S long |
SR UFP |
RB |
3C |
Later |
OESL |
Skye |
FVP |
8925 |
V 7/16TS NHC*NHB |
S 5 DG3+6 |
CO* UFP SENS |
P RB 3/52 |
3C 2H |
4”P |
Gloucestershire |
FV |
8964 |
V NTS NHC HB |
S |
SR UFP SENS |
P RB 2/52 |
3C |
4”P |
Webbed crankcase OESL |
Lincs |
The Engine Support Lug,
according to the BS parts list, was changed at S/No.10000. The original ones
are described in the parts list as ‘Engine Support Lug fitted to bottom half
of crankcase’ and were fitted up to 10000. The later ones were described as ‘Engine
Support Lug fitted to top end of Transmission Casing Tube’ and were fitted
from engine number 10000 upwards. I am therefore now only recording the type
of Engine Support Lug for those engines with serial numbers in the range 7000 to
13000 and using the acronyms OESL (Original Engine Support Lug) and NESL (New
Engine Support Lug). We can speculate that the
Original Engine Support Lug (OESL) was possibly last fitted in the 9000s, and
the new Engine Support Lug (NESL) was probably first fitted at 10000. This
probably means that not all the numbers in the 9000s were allocated, and
indeed, to date, the recording of known engines before 10000 seems to come to
a halt at 8964. |
FVP |
10021 |
V 7/16TS NHC HB |
S 5 |
SR UFP |
P RB |
3C |
P 4” |
NESL UFP |
FVP |
10048 |
S 5 |
CO |
4C |
NESL |
Flintshire |
FVP |
10056 |
V HB |
T NS |
CO PFP(B) |
RB |
3C |
5.4”SBPort |
NESL |
On e bay 7/19 |
FVP |
10090 |
Notts |
FVP |
10152 |
V |
CO |
Wipac |
FVP |
10327 |
V |
S 5 NS Grip |
CO UFP SENS |
P RB |
3C |
NESL |
On e bay 3/16 |
FVP |
10341 |
On e bay 7/18 |
FV |
10349 |
V |
S |
SR |
3C |
NESL |
e bay July 2014 |
FVP |
10359 |
FVP |
10422 |
T 10* |
P HRB 5/52 |
3C 2H |
NESL |
Gloucestershire |
FVP |
10469 |
V |
S |
SR UFP |
RB |
3C |
On e bay 9/17 |
FVP |
10495 |
V 1/2 |
S 5 |
CO NSPFP(B) |
P RB |
4 |
Later |
NESL |
FVP |
10528 |
S then T |
SR |
1952 owner was Mr F Peters.
Modified to T by BS in 1955 |
St Mawes |
FVP |
10562 |
V |
S 5 |
CO |
P RB |
4C |
Later |
NESL |
On e bay Mar 2015 |
FVP |
10693 |
V7/16 TS NHC HB |
S |
SR*UFP |
P RB 5/52 |
NESL |
Fife |
At approx this point, the Long(er)
Stroke LS was introduced; producing a capacity of 64cc whilst
retaining the same 45mm bore as the FV/FVP. It had a different, bigger
crankcase to the FV/FVP and was the first engine of this capacity. It utilised the big 10:35 ratio gearbox with prop, and long tubes from
the FVP which it appears to have replaced. S/No 11408 is the earliest LS
of which I have a record. It is perhaps possible that the LS was introduced
at around S/No 11000; or it might have even been at 10000. I suspect that the
New Engine Support Lug (NESL) which locates around the drive shaft tube, was
present from the start on this model. The parts list also infers that
the Stub Tiller was not fitted after 11000. The evidence collected here would
support that inference. The evidence would also suggest
that the tilting tiller was possibly never an option on new FV/ FVPs. With
the introduction of the LS, all tillers appear to be tilting. Earlier FV/FVPs
appear to be sometimes fitted at overhaul/repair with a tilting tiller. This must have been especially so, when
stocks of crankcases with tiller stubs were no longer available after
11000. The use of the ‘T’ suffix
appears to be inconsistent; probably due to which company carried out the
repair. Other changes which might have
occurred at about this point were:- 1. The change to the magneto
from a Rimless Baseplate (RB) to a Half Rimless Baseplate
(HRB) ie a rim was added around half of the baseplate. 2. The introduction of the
drain Hole in the top of the Bowl (HB) of the carburettor. 3. The introduction of a small
air Hole in the Choke shutter (HC). 4. The metal ‘U’ Fuel Pipe (UFP),
superseding the Lopped Fuel Pipe (LFP). |
FVP |
11267 |
V 7/16 TS NHC HB |
T NS |
CO PFP |
For RB 4/52 |
4C 2H |
5.4”SBPort |
NESL Webbed crankcase. 4 extra water inlet holes. |
FVP |
11296 |
Crankcases driveshaft tube |
FV11364 was the last to be
produced in 1952. FV11365 was the first to be
produced in 1953. |
LS |
11408 |
V |
T 12 |
¾” UFP SENS |
P RB |
4C |
4”P |
NESL |
ebay Aug 2017 |
LS |
11413 |
V |
T |
4 |
U |
NESL |
e bayApril2014 |
LS |
11510 |
V HB |
T |
3/4" |
P |
SOS Site |
FV |
11716 |
V 7/16TS HC HB |
T 10 |
CO* UFP* |
P RB |
3C |
4”P |
NESL |
LS |
11751 |
V7/16TS HC HB |
T 10 |
3/4" |
HRB |
4C 2H |
4”P |
Dismantled and bits sold |
e bayJan2015 |
LS |
11755 |
V NHC |
T 10 |
3/4" NS FP |
P HRB |
4C 3H |
None |
CBPH NESL |
On e bay Feb 2015 |
LS |
11897 |
NESL Later CBPH |
On e bay 3/18 |
LS |
11947 |
V HB |
T |
3/4” UFP |
In RB |
4C |
5.4”SBPort |
NESL |
On e bay 3/19 |
FV |
11973 |
T |
NESL c’case assy only |
Gloucestershire |
FV |
12044 |
V |
NS T |
SR UFP |
3C |
NESL |
E bay July 2017 |
FV |
12112 |
V NTS |
T 10 DG3+6 |
SR UFP SEWS |
In HRB |
4C |
NESL |
Stevenage |
FV |
12206 |
V7/16 HB NHC |
T 10 DG3+6 |
SR UFP |
In HRB 12/52 |
4C 2H |
5.4”SBPort |
NESL Champion PC |
Guildford |
FV |
12460 |
V |
T |
3/4"UFP |
In |
4C |
UL |
NESL |
e bay Aug2014 |
FV |
12508 |
None |
T? |
None |
NESL. Dismantled/scrapped |
FV |
12644 |
V TS |
P HRB 4/53 |
NESL P’head only |
Gloucestershire |
LS |
12667 |
V 1/2 |
T 12 |
P HRB 1/53 |
4C |
NESL |
FV |
12828 |
T Long |
SR |
3 |
U |
NESL |
On the web |
LS |
12991 |
T G 6S |
4C 2H |
5.4”SBPort |
NESL |
New York |
LS |
13081 |
T |
Crankcase assy |
Gloucestershire |
FV |
13521 |
V ½ TS HB HC |
T 10 DG 3+6 |
SR UFP |
In HRB 5/53 |
3C |
4”P |
Flintshire |
LS |
13824 |
V 1/2TS |
T 10 |
3/4"UFP |
HRB |
4C |
LS |
13906 |
V HB HC |
T12 DG3+6 |
HRB |
4C 2H |
NS 5.4” |
NESL CBPH |
On ebay 8/17 |
LS |
14248 |
V |
T 10 |
3/4” PFP© |
NS |
5.4”SBPort |
On ebay 3/18 |
FV |
14847 |
V |
T |
CO |
In |
3C |
e bayAug2014 |
LS |
14905 |
Ebay May 16 |
FV |
14942 |
T |
Crankcase only |
Fife |
LS |
15005 |
V HB NHC |
T |
UFP |
In HRB |
4C |
Hertfordshire |
FV |
15020 |
V |
T DG3+6 |
CO UFP |
3C |
NESL TPH |
Skye |
LS |
15046 |
T |
Powerhead assy only |
e bay Nov2014 |
FV |
15425 |
Scotland |
LS |
15703 |
V |
T |
3/4" |
In |
4C |
Fixed |
SOS site |
LS |
15869L |
LS |
16445 |
V 7/16 NHC |
T 10 DG3+6 |
3/4” NSPFP |
In HRB |
4C 2H |
5.4”SBPort |
NESL TPH |
e bay Mar 2015 |
LS |
16727 |
V NHC |
T NS |
7/16 PFP(B) |
For |
4C |
Later |
NESL TPH |
e bay Feb2016 |
LS |
17028 |
NESL |
LS17828 was the last to be
produced in 1953. LS17829 was the first to be
produced in 1954. |
LS |
18407 |
V7/16NTS HC* HB* |
T 10 |
3/4"NS? UFP |
In HRB 1/54 |
4C 3H* |
5.4” SBPort |
FV |
18785 |
V |
T NS |
CO UFP |
In HRB |
3C |
5.4” SBPort |
TPH NESL |
Bermuda |
LS |
18849 |
V 7/16NTS HC HB |
T 10 |
Long range UFP |
In HRB |
4C 2H* |
5.4”SBPort |
NESL
TPH |
FV |
18928 |
V |
T |
SR |
Not P |
3C |
e bay June2014 |
LS |
19267 |
V HB |
T |
Long range PFP(B) |
In HRB |
4C |
5.4”SBPort Cotton reel |
Straight Villiers Lever |
e bay Mar 2015 |
FV |
19304 |
None |
It was possibly around this
point that the metal ‘U’ Fuel Pipe (UFP) was replaced by the Plastic Fuel
Pipe (PFP). |
FV |
19309 |
V 7/16NTS NHC HB |
T 10 |
CO LFP* |
In HRB to RB* |
3C |
5.4”SBPort |
LS |
19441 |
V |
T 10 |
7/16” PFP |
In |
4C |
5.4”SBPort |
TPH |
Hampshire |
FV |
19742 |
V |
T |
CO |
4 |
e bayApril2014 |
LS |
20101 |
V HB HC |
T 10 DG 3-6 |
PFP(B) |
In HRB |
Later 3H |
Later |
TPH |
Brockenhurst |
LS |
20187 |
T |
7/16” SEWS |
In HRB |
4C |
5.4”SBPort |
TPH |
Nova Scotia |
LS |
20440 |
V |
T |
7/16” |
In HRB |
4C |
TPH |
LS |
20623 |
V NHC |
T 10 |
7/16” PFP(B) |
HRB |
4C |
TPH |
Orkney |
LS |
20964L |
V 1/2 |
T 10 |
3/4" |
4C |
TPH OD-Sailorman |
LS |
21487 |
V |
T |
4C |
On e bay 4/14 |
LS |
21885 |
V |
T |
¾” |
HRB |
Later |
5.4”SBPort |
TPH |
Fife |
LS |
22022 |
V |
LS |
22367 |
V |
T10 NS G |
3/4” NSPFP |
In or F HRB |
4C |
TPH |
e bay Oct 2015 |
LS |
22689 |
In bits |
e bayAug2014 |
It is possible that
approximately around this point the LS 3/4" radius tank (of dims L=10.45
W=4.47 H=3.09) was replaced by the 7/16” radius one (of dims L=10.00 W=5.00
H=3.39). These dims recorded here are based on measuring just a few dented
tanks, so should be used with great caution. It is worth noting that the FV/FVP canted oval tank has the same
overall dimensions as the 3/4" radius tank. It is probably that the
FV/FVP canted oval tank was developed after the introduction of this first
horizontal LS tank. Indeed the roots of this first LS tank can be traced back
further, as the first tank in this range – the small round tank - had the
same length of 10.45 and diameter/height of 3.09. |
LS |
22721 |
V |
T |
Later PFP |
4 Later |
Fixed |
TPH |
e bay Oct2014 |
LS |
22723 |
Powerhead only |
Orkney |
LS |
22741 |
T |
Powerhead only |
e bay Nov2014 |
LS |
22768 |
V7/16 NTS HC HB |
T 10 DG3+6 |
7/16” |
In HRB |
4C 2H |
5.4”SBPort |
TPH Very little use |
LS |
23321 |
V HC HB |
T10 Not DG |
7/16”? PFP(B) |
In HRB |
4C Slots |
Later |
TPH |
e bay Mar2015 |
LS |
23745 |
T 10 |
4C |
Flintshire |
LS |
23846 |
V |
T 10 DG3+6 |
NSPFP |
HRB |
4C |
Later |
CBPH Seized |
Illminster |
LS |
24100 |
V7/16NTS HC HB |
T 10 DG3+6 |
7/16"PFP(B) SENS |
In HRB 7/54 |
4C 3H |
5.4”SBPort |
TPH |
It would appear that around
this point, the Clamp Bolt Pump Housing (CBPH)
superseded the Threaded Pump Housing (TPH). I am therefore now only
recording the type of Pump Housing for serial numbers in the range 20000 to
30000. |
LS |
24747 |
V7/16 NTS HC HB |
T 10 DG3+6 |
7/16”PFP(B) |
In HRB 8/54 |
4C 3H |
CBPH |
Tasmania |
LS |
25120 |
Crankcase assy only |
New York |
LS |
25322 |
V |
T |
7/16”PFP(B) SE?S |
4C |
5.4”SBPort |
CBPH |
New South Wales |
LS |
25408 |
V HC HB |
T 10 DG3+6 |
7/16” PFP(B) |
In HRB 8/54 |
- 3H |
5.4”SBPort |
CBPH |
LS |
26004 |
V |
T DG3+6 |
7/16” SE?S NSFP |
HRB |
4C |
5.4”SBPort |
CBPH |
LS |
26125 |
V7/16NTS HC HB |
T 10 DG3+6 |
7/16” NSPFP |
In HRB 10/54 |
4C 3H |
5.4”SBPort |
CBPH |
LS |
26344 |
V HC |
T 10 NS Grip |
7/16” FP(B) SENS |
HRB |
4C 3H |
5.4”SBPort |
CBPH |
On e bay 3/19 |
LS |
26565 |
V HC |
T 10 DG3+6 |
7/16” SE?S PFP(B) |
IN HRB |
4C |
5.4”SBPort |
CBPH. Top clamp bolt & NESL
screws wire locked |
N |
LS |
26707 |
V |
T NS |
PFP(C) TE?S |
HRB |
4C |
5.4”SBPort CR |
CBPH |
ebay Jan2017 |
LS |
26743 |
NSW |
LS |
26748 |
V |
T 10 DG3+6 |
7/16” PFP(B) |
In HRB |
4C 3H |
5.4|”SBPort |
CBPH |
NSW |
LS27084 was the last to be
produced in 1954. LS27085 was the first to be
produced in 1955. |
LS |
27327L |
V Later |
T 10 |
7/16” |
HRB |
4C 3H |
5.4”SBPort |
CBPH |
NSW |
LS |
27489L |
V7/16NTS HC HB |
T 10 |
HRB |
4C |
CBPH OD-Seagull |
LS |
28457 |
V |
Later PFP(B) |
4C |
Later |
CBPH |
e bay Sept2014 |
LS |
28708 |
V HC |
T 10 DG3+6 |
Later tank PFP(C) |
In HRB |
4C 3H |
5.4”SBPort |
CBPH |
NSW |
LS |
29086 |
V |
T |
Later PFP |
In |
4C |
Later |
CBPH |
e bay Aug2014 |
LM |
29462 |
V HC |
T DG3+6 |
7/16”PFP(B) SE?S |
In HRB |
4C |
5.4”SBPort |
CBPH |
On e bay 4/19 |
LS |
29789 |
V NTS HC HB |
T 10 DG3+6 |
PFP(C) |
In HRB |
CBPH Dismantled and parts sold |
e bayMarch2016 |
LM |
29941 |
V7/16NTS HC HB |
T 10* DG3+6 |
7/16”* TEWS* PFP(B) |
In HRB 3/55 |
4C(6”) |
5.4”SBPort |
CBPH |
Gloucestershire |
The LM is identical to the LS
except it has the small 10:21 ratio gearbox and smaller prop and the shorter
drive shaft and exhaust tubes as per the FV. These two production numbered
LMs proves conclusively, if that was ever required, that the LM was a genuine
production model. |
LS |
30008L |
Maldon |
LS |
30121 |
V ½ NHC NHB |
T |
UFP ?EWS |
In* HRB |
4C |
Later |
LS |
30524 |
V |
Later T |
7/16”PFP© |
In HRB |
5.4”SBPort |
Slotted gearbox CBPH |
Orkney |
LS |
30581 |
V HC |
T NS |
7/16”PFP(B) TEWS |
In/For |
NS |
Later |
Slotted gearbox |
Whitchurch |
LS |
30749 |
Cramkcase only |
Flintshire |
LS |
31003 |
V7/16NTS HC HB |
T 10 |
7/16” PFP |
In |
4C |
UL |
OD |
LS |
31101 |
V HB |
T 10 |
7/16” PFP(B) |
In |
4C 3H |
5.4”SBPort |
e bayMarch2015 |
LS |
31369 |
V HB |
T 10 DG3+6 |
‘Long range’ |
4C 3H |
5.4”SBPort CR |
ebay Feb 2017 |
LS |
32661 |
V 7/16” HB HC |
T 12 |
Wipac |
4C |
Flintshire |
LS |
32668 |
V |
T 12 |
7/16”PFP(C) BE?S |
For |
4C |
5.4”SBPort |
e bay May2015 |
LS |
32827 |
V |
T10 |
7/16”PFP(B) |
In |
4C |
5.4”SBPort |
On e bay 7/19 |
LS |
33186 |
7/55 |
Powerhead only |
Gloucestershire |
LS |
33346 |
V 7/16 HB HC |
T 10 |
7/16” PFP(B) |
In HRB 8/55 |
4C |
5.4”SBPort |
Flintshire |
LS |
33642 |
V HB |
T10 DG3+6 |
7/16” |
In HRB |
4C 3H |
5.4”SBPort |
South Australia |
LS |
33945L |
V |
In HRB |
Sweden |
LS |
34482 |
V |
T NS Grip |
7/16” SE?S PFP(C) |
4C |
NS |
LS |
34640 |
T |
In HRB |
4 Later |
Later |
Australia |
LS35003 was the last to be
produced in 1955. LS35004 was the first to be
produced in 1956. |
LS |
35006 |
V HC HB |
T 12 6SGrip |
7/16”PFP(C) SE?S |
In HRB |
4C 3H |
5.4”SBPort |
Melbourne |
LS |
35222 |
V HC |
T 10 |
7/16”PFP(C) |
In HRB |
4C |
None |
e bay Mar 2015 |
LS |
35744 |
V7/16NTS HC HB |
T 10 |
7/16” PFP |
In HRB |
4C 3H |
?5.4”SBPort Plated* |
LS |
35887 |
V |
T 10 |
7/16” SEWS PFP(C) |
In HRB |
4C |
5.4”SBPort |
e bay May 2017 Burgess Hill |
LS |
36402? |
Possibly 36442 |
LS |
36442? |
Crankcase only |
Kent |
LS |
36688 |
V7/16NTS HC HB |
T 10 No Grip |
7/16” PFP(C) |
For HRB |
4C 3H |
5.4”SBPort Ali thrust now CR |
LS |
37004 |
T |
4C 3H |
1 small hole in exhaust Incomplete/in bits |
ebayAug2017 |
LS |
37229 |
V |
T 10? DG3+6 |
7/16”SEWS PFP(C) |
For HRB |
4C |
5.4”SBPort |
Sailorman |
EBay March 2016 |
LS |
37648 Poss 36748 |
Rebuilt by Classic Seagulls
using crankcase from LS14248 inFeb2016 |
LS |
37845L |
V |
T 10 |
7/16”PFP(C) |
For HRB |
4C |
Later |
LythamStAnnes |
LS |
37902 |
LS |
38004 |
V |
7/16” |
4C |
London |
LS |
38087 |
V |
T 12 |
Later PFP |
Wipac |
Later 3H |
Later |
LS38324 was the last to be
produced in 1956. LS38325 was the first to be
produced in 1957. |
LM |
383R |
V 1/2TS RH Choke |
T 10 |
3/4” |
4C |
CBPH NESL OD-Sailorman |
FVP |
None |
Serial number is not stamped |
FV |
1XXXX |
T |
SR |
Number ground off. Powerhead and tank only |
Gloucestershire |
SPS |
64082 |
V HC |
T |
PFP(C) |
HRB |
3C (FVP) 3H |
5.42SBPort |
CBPH |
LS |
38344 |
by John Williams, this would appear to have been the last engine of this
series |
After the LSs came the SJMs and
the SJPs. Well not quite, as there was an overlap when the all three were
being produced simultaneously. Probably also some LMs were produced as well
during this period. It is interesting how the Early
Series Forty models were developed during their production. The introduction
of the ‘big’ gearbox for the FVP was a success, as was the introduction of
the LS, which I have suggested stood for Long(er) Stroke. This
longer stroke unit, compared to the FV/FVP, increased the capacity by about
9cc to 64cc. The crankcase corrosion issue
was addressed by the introduction of the SJM/SJP, which I have suggested
stood for Sealed Jacket Minus/Plus. In this unit the cooling
water was in a Sealed Jacket cylinder block design and thus water
could not be in contact with the crankcase to cause corrosion. In the last 2 years or so of
the production of the Early Series Forty Models, the SJM/SJPs were being
produced alongside them in steadily increasing numbers as the following table
shows. This overlap allowed efficient commonality of parts between the two
designs and time to resolve any potential design or production problems. The following production
figures assume all the serial numbers were allocated. |
Year |
SJM/SJP Serial #s |
SJM/SJP Quantity |
LS/LM Serial #s |
LS/LM Quantity |
Total Annual Quantity |
1955 |
10 to 586 |
577 |
27085 to 35003 |
7,919 |
8,496 |
1956 |
587 to 3903 |
3,317 |
35004 to 38324 |
3,321 |
6,638 |
1957 |
3904 to 9772 |
5,869 |
38325 to 38344 |
20 |
5,889 |
Jeremy L Prince (Contactable on the SOS Owners
Forum, username Gannet) Updated February 2021 |
