What’s this?
What’s this?
Postby Oyster 49 » Tue Oct 31, 2017 10:21 am
Just spotted this on eBay, it looks like a lot like a BMB leg, but not sure what the rest of it is. Any suggestions? Just curious really.
https://www.ebay.co.uk/itm/Vintage-Outb ... Sw4PxZ9xEC
Re: What’s this?
Postby Keith.P » Tue Oct 31, 2017 11:42 am
Looks like a briggs & stratton outboard, What name it goes by, I wouldn't no, it's not a jetmaster.
I have seen another motor on Ebay with a mower engine, they turn up from time to time.
The only one I know is the Ocean outboard with a Tecumseh engine, only because I have one, but don't tell anyone. :oops:
Liam2k3
Re: What’s this?
Postby Liam2k3 » Tue Oct 31, 2017 11:43 pm
Something else curious on ebay.
https://rover.ebay.com/rover/0/0/0?mpre ... 2723147109
Looks like a century plus gearbox and stem but has a strange collar at the top,no clutch rod and a left handed aluminium prop.
Re: What’s this?
Postby Keith.P » Wed Nov 01, 2017 1:17 am
Part seagull, part strimmer and still only good for parts.
Re: What’s this?
Postby AusAnzani » Wed Nov 01, 2017 5:29 am
The first one looks like an adaptation to me, Briggs engine atop a BMB mid and lower.
Have a similar contraption in my collection, Aussie Seamaster engine atop a BMB mid and lower. Two half inch drive sockets welded back to back form the coupling between the crank and the drive shaft. Pretty clever at first glance, but when i realised they butchered the original crank to make it all go together, I let loose with a few expletives.
Re: What’s this?
Postby Collector Inspector » Wed Nov 01, 2017 8:41 am
Oyster 49 wrote:Just spotted this on eBay, it looks like a lot like a BMB leg, but not sure what the rest of it is. Any suggestions? Just curious really.
I will never be able to un-see that mess.
Re: What’s this?
Postby Oyster 49 » Sat Nov 04, 2017 12:23 am
I know what you mean! Horrible piece of engineering!
Ozzmotorz
Re: What’s this?
Postby Ozzmotorz » Tue Nov 28, 2017 8:44 am
It must be fairly common, as I also have one. Same lower unit, but with a victa lawnmower engine adapted. It also was poorly engineered, and only run for a short time, before it flogged out the crankshaft bearings. Lol
Re: What’s this?
Postby AusAnzani » Wed Nov 29, 2017 3:30 am
The engineering on this one looked pretty good actually. They had machined up a block of aluminium to act as the interface between the Seamaster engine and BMB lower. They also got lucky in that the Seamaster exhaust manifold mated perfectly with the inlet at the top of the BMB leg. To facilitate the fit, all they needed to do was to machine the above mentioned piece of aluminium to the correct thickness (height).
You can see the machined block just behind the tiller bracket.
I was however dissappointed to find they had unnecessarily butchered the lower crank shaft section ie so that they could use their back to back welded socket coupling to connect it to the drive shaft. Why they didn't just modify the drive shaft to fit the original crank coupling set up, i do not know!
Although this didn't have the cowl sections or carby and throttle I needed to finish of my Seamaster, I bought it anyway just for the spares. Seamaster bits are hard to find these days!
Return to “Other Old Outboards (Non-Seagulls)”
Who is online
Users browsing this forum: No registered users and 5 guests
