Chain
- Rob Ripley
Chain
What shape/type/size chain is used to secure the Thrust Block Locking Latch with the split pin ?
Re: Chain
Hugz posted this photo in the wanted area think I have seen similar at Bunnings if you find any local let us know.Rob Ripley wrote:What shape/type/size chain is used to secure the Thrust Block Locking Latch with the split pin ?
Re: Chain
I'm sure I've seen the same chain on old picture frames. Has anyone tried a framing shop?
- Rob Ripley
Re: Chain
I found it ! at my favourite shop ...... Bunnings ! The only catch is that it is chrome plated.
Re: Chain
Hi there,
The flat link brass chain you're looking for is chandelier chain.
If you don't want the chrome plated stuff then I suggest you do a search on Amazon for "chandelier chain".
The search results will include normal oval link chain - but you'll also get a few examples of the flat link, brass chandelier chain that you're trying to source.
Hope this helps!
Hope this helps!
Re: Chain
Picclick uk.
- Attachments
- 1m-NEW-Solid-Brass-19mm-Flat-Link-Polished.jpg (30.01 KiB) Viewed 1456 times
Re: Chain
£6 a meter free shipping.
Re: Chain
This chain comes in several link sizes, Hugo how many links in 2 inches of chain?
Re: Chain
I'm getting 5 links =3" china
Re: Chain
Just been relisted if anyone interested item no
392231083944 flebay
392231083944 flebay
- Attachments
- 1m-NEW-Solid-Brass-19mm-Flat-Link-Polished.jpg (30.01 KiB) Viewed 1435 times
- Rob Ripley
Re: Chain
The Bunnings links are 1 1/2 links per inch, I think I'll look for the finer brass links.
Re: Chain
I've been talking to everyone I know who's got a skeletal bracket to find the details of their safety chandelier chains, the pitch of the chain seems to be 2.5 links per inch, which is the same as the safety chain on the bayonet fuel cap & the retaining chain on the locking pin that stops the motor falling off the transom bracket.
