102 gearbox ratios
102 gearbox ratios
Charles, you state to John1952 in his query regarding propeller evolution:
'Late forties early fifties there was a bit of experimentation, and higher power/slower revving motors ended up with more blades of a larger clover-leaf shape.'
Does this mean the 102 boxes, apart from the Plus, do have different ratios? If so can they be externally distinguished?
I was counting on them all being 12:30!
No. What I meant was the experimentation was with props. The gearboxes are (basically) the small and sleek or the ones like a turnip.
I regret that you're back to nitrous oxide in your search for greater power. Either that or the other Charles will come in here and tell you exactly which block (big porting differences) mated with which gearbox and which prop will give you the best power output for your craft.
B.S. did give this a bit of thought, and they never turned this into a production model.
Come on Charles, share a bit of the mother lode of Seagull tuning lore...
I've been called a Moron before, but never an oxymoron do I have to get an O2 mobile phone?
Sorry your not going to get big porting diffences with 102 cylinders, only minor ones.
So here's your shopping list,
SD cylinder with cleaned & gas flowed ports, clean water jacket & 5/8" reach spark plug.
SD crankcase with new main bearings, reconditioned needle roller crankshaft with new pin & new big & little end bearings, Crankcase internal volume to be reduced, to suit crankshaft & increase crankcase compression.
Depending on how well you've gas flowed the inlet port, a new Amal 416 or 418 carb & a selection of suitable main jets.
Now the bottom end.
Model 75 water pump housing & a century water delivery pipe ( to be cut & fitted later) featherweight gear box with a modified propshaft to accept Yamaha or Mariner 3 bladed 4hp shearpin prop.
Come back to me when you've collected all the above & I'll talk you through assembly & the ignition permutations.
Now the bottom end.
- timberman2004
I find that the ones with a fold away hood, and both zip and Velcro are best. But don't forget that they best made from Gortex fabric and need to have a draw string aroung the waist.
P.S. Have not told H.I.D. that I have a new Ebay shopping list for the super fast Seagull project, at least it will make a change from searching for "mens lightweight waterproof coats"
Talking about race tuning - putting the 170 back together after its sonic vibration deep clean - I found the Amal 420 needle has three holding slots.
Well, this is an option too far, more than I can contend with. It seemed to work perfectly well using 25:1 mix on the bottom slot with plug the right colour.
Do I experiment on a weaker mix by dropping the needle a slot?
The carb was made by Amal for any 2 stroke motor manufacturer who required a 20mm carb for their application, depending on their needs & performance requirements.
The 420 as fitted by Seagull to the 170 or the 160 inboard was fitted with a 140 main jet, which enabled the owner to fine tune their mixture without going to the expense of ordering a larger or smaller main jet, whilst in use.
Can I have a red anorack without a hood, Gortex would be nice too!
