Smoke. Muncie Neptune Vs Seagull
It was hot and humid yesterday so with nothing better to do I decided to try running an early Muncie Neptune that I got from the states which has been lying underfoot for ages.
OK, the smoke part. We all know that Our Gulls smoke when things are going well.
At the end of my latest You Tube Vid of the Neptune, it runs with NO smoke at all.
http://au.youtube.com/watch?v=c1H38kde- ... annel_page
Considering that the mix instructions on the flywheel said to feed it 1 pint to the gallon I am amazed.
Maybe the Tillotson multi jet carb has something to do with it along with reed induction matched with timed advance/throttle control etc.
Any thoughts?
C.I.
Any thoughts?
C.I.
Us Seagull fetishists have always felt that you need some compression to allmost burn your lubrication to produce smoke.
There is the fact that Seagull smoke prevents the male salt water croc from smelling the females "on heat" scent, so efficiently,that there have been no records found of any successful hatchings in the wild in the UK.
You could have something there!
No Crocks, in Northern Australia, have EVER taken a bite out of a tinny sporting a Seagull!
Therefore, logically, blue smoke must actually calm them down.....
Statistics prove that!
Statistics can prove that anything is possible when taking this approach but.
Hmmm, maybe a Gull in the Swag next trip Outback, just to be on the safe side eh?
Why?.............Monster Carnivore Wombats Mate!
C.I.
C.I.
Yes it even works on them, too.
Even more advantages.
Mind you, they are proven to be allergic to anything metal that has been in contact with oil.
Current Primary Woman has this allergy so badly that she has felt it necessary to request that the prized 102 in the dining room should now reside elsewhere. Bless her. I shall be moving it to the living room this afternoon; we'll see if that helps.
So that includes Sewing machine, chip pan, lawnmower, oven & handcuffs, though there is a way around this.
Charles could you ask John when he's getting the new fuel tank transfers produced to change the artwork to Organic British Seagull. built by happy fairtrade Seagull employees in their heritage location of Poole, suitable for use with Allo Vera oil.
What Charles P doesn't know, is that I'm going to sent this caribean gentleman around to his house, as he only lives 200 meters from the water in Poole harbour so his new friend will have somewhere to park his boat & he won't even be out of breath.
My question to him was what does it say on this fellow's job description?
- timberman2004
I had similar queries re the bumboatman
the ad that charles P posted up here would have the 'pink' press all of aquiver .....and the rest of the press in a self-induced steaming moral outrage
personally I loved it ..(and would appreciate a full sized copy)
Doubtless thoroughly well intentioned, even then, but it doesn't reeeeely help that the chap taking his ease is obviously a quintissential Englishman tugging on his pipe, whilst it's the newly liberated ...er...bumboy... is ..um....still doing the business ... <<no, I think I'll quit here while I'm ahead >>
Such an ad in todays moral clime makes my previous comments on 'regularising' Ebay bidding seem positively tame
Must restore the P.C. equlibrium, owning polluting old outboards is probably non P.C. enough.
A Bumboat is:-
A small boat used to ferry supplies to ships moored away from the shore. Originally referring to a scavenger's boat, the name comes from the combination of the Dutch word for a canoe, "boomschuit" ("boom" meaning "tree") and "boat".
There you have it "Boomschuit" great name for my newly sorted fast racing hull.
A Bumboat is:-
