Motor slows down after a minute at WOT
My Forty Plus starts up great - runs well. Except that when I go wide open I get about a minute or so of full power then the motors backs off a bit, even surges a bit - which leans toward a fuel issue in my mind.
After I throttle down for a minute or two - the motors runs WOT again no problem. Then the cycle repeats.
Any ideas on what to check or look at? I cleaned out the carb - motor doesn't seem to have fue issues - but I am no expert. Is there a tank filter I should check?
Any other ideas?
Thanks
Derek.-
Any other ideas?
Thanks
Derek.-
Hi Derek,
If you could post the engine number the real experts could probably be more specific.
Yes, it does sound like fuel starvation ( mixture going weak as the fuel supply can't keep up with the demand at WOT ) Assuming you have the most common villiers carbed 40+ there most certainly is a tank filter to check, its on the top of the fuel tap, just remove the tap, there is also another in the 'banjo' connection where the fuel line connects to the carb. Check also you don't have an air lock / bubble / sediment / goo in the fuel line.
There are other things that could cause this ( like an air leak somewhere that only opens up fully when hot - motors can get very cranky when they have air leaks ) but I would check the filters first.
If there are no more leaks on the crank case, then it must be getting more air in from somewhere, have you got any play in the crank itself, as they are only bushed and they maybe a bit worn and could pull air in at WOT, other than that pop the carb needle up one notch for a stronger mix and give it a run.
I love Jiggling my jiggler.
OK. Sorry, all the above is for fuel except you have not specified oil mixture that it is on?
If all above is cleaned and jiggled and correct mix with little or no improvement, open the gap on your plug a little bit.
Kinda "Little Jiggle" like..........0.025" Start at 0.028" first and work back slightly.
Never know, could be "Juicing Up" like the yanks say.
Another thing to try is WOT and then back off till the revs drop a tad. You will hear a slight drop in revs and see how that goes. Gets the carb back into "Perspective"
All Old Dears are different. Like a H.I.D, takes a bit of practice to work them out individually.
Best of luck as I have had a few HIDs and I failed to work any of them out...........
C.I.
C.I.
If you change from 10:1 to 25:1 there would theoretically be no performance changes. The reason that changes are made to the needle or jets is to adjust for the lesser viscosity of the lower oil content. This prevents the motor from running too rich.
There is a school of thought that would suggest making noi change in your case until your problem is sorted. If it should turn out, as has been suggested, that your bearings are a little worn, allowing air into the crankcase, then less oil may make the problem worse.
In general I prefer to leave the motors at 10:1 if that's the way they were designed.
