The motor was expensive to buy back then Yes!
A selection of replacement parts and listed prices, from document. Pounds.shillings.pence.......
Fly Wheel and Magneto Assy 5.0.0
Carburetter with control lever and cable 1. 12. 9
Carburetter air intake 0.2.0
Crankcase with bush and studs, driving side 1.0.0
Crankcase with bush and studs Transfer Side 1.0.0
Crankshaft 2.0.0
Connecting Rod 0.17.06
Cylinder Only 2.5.0
Drive Shaft 23" 1.10.0
Drive shaft 29" 2.0.0
Bevel Gear Casing 3.5.0
Propellor 0.15.0
Petrol Tank Less Fittings 1.7.6
Silencer 1.15.0
Spark Plug and Washer 0.3.6
Tiller 0.15.0
Transom Bracket 1.5.0
Piston 0.12.6
Swivel Bracket 0.9.0
I like this one
Starting Cord with Handle 0.1.0
Parts "Gouging" started early on!
OA Parts Prices 1931-2
