What carby is this ?
- Rob Ripley
I recently came into possession of a box of bits ... The carby does not seem to match.
Re: What carby is this ?
What's the carb number?
Hi Rob,
It looks as if the float bowl has a top feed. Is that correct?
What is the through bore size?
Thanks
Thanks
Anzani 6hp carb & parts
Nice top feed Amal. It looks like he clamp is designed to fit on the intake where a shroud would normally go on a Seagull, and on the two studs which are then protruding fits what is the choke lever, pivoting on one of the studs, and then the raised disc goes on to act as a bit of a cover, held on by two washers and nuts, similar to an Anzani Pilot with an Amal carb. Does this work?
The early Britannia Light twin had this choke arrangement, circa early 1931-33. However the throttle was lever operated. No cable
- Rob Ripley
The choke/cover screws onto the same thread that the shroud does for the Seagull. The carby has these numbers 22 028 and 4E0, incidentally I can't find any identifying numbers on the Amal carbies on my 102 Seagulls !
