trolley
ollyboy11
trolley
Post by ollyboy11 »
g'day gang, peter here from hervey bay in qld
i'm a new chum as far as seagulls go although i bought a new one back in the 80s and i've had boats most of my life.
i recently bought a seagull espc 179 ff0 and i'm in the process of doing her up
i want to make a trolley to put the motor on to work on and store also i should be able to put a container of water under the motor so as to run the it
what i need is plans, drawings, photos, anything to give me an idea of how to go about it. i think it needs to be well balanced, that's about all i have
so any help or advice is welcome
thanks peter
Re: trolley
Peter
Easy thing is to get something like this....
http://www.ebay.com.au/itm/OUTBOARD-TRO ... 1438.l2649
Most marine dealers or chandlers have them as well. Splash out a bit more for the 4 wheel version as placing a tub of water is easier.
Good luck and remember PICS!
We love pics aye.
ollyboy11
Re: trolley
Post by ollyboy11 »
hey bnc, mate if i wanted easy i wouldn't have bought a seagull :lol: i made one which cost me the the cost of the wheels and axle the rest of the stuff, i had here. i'd post a pic if i knew how to do it
Re: trolley
When you reply to a post/start a thread you will see a tab below yr text box labelled Attachments.
Click on it and follow the instructions.
Just like copy paste?
BnC (Bruce)
ollyboy11
Re: trolley
Post by ollyboy11 »
Re: trolley
I've seen outboards moved about using a simple sack truck, quite an effective method.
pat777
Re: trolley
Post by pat777 »
This thread was double posted, here is a link to previous discussion on the subject.
viewtopic.php?f=2&t=6324
It came out looking well in the end Peter, Nice to have a one of a kind trolley that you've made yourself.
You just need the plastic end caps for the steel box section to finish it off! My local steel yard sells them, so I presume it is something that most steel yards stock.
I presume given the colour of the HT lead that it has been replaced at some stage. Did you replace it yourself?
How did the connection work out inside the flywheel? I thought it was not possible to replace the ht lead on that particular model. (I could well be mistaken though.)
ollyboy11
Re: trolley
Post by ollyboy11 »
g'day, yeah, i don't know what happened with the double posting.
thanks on the trolly, i don't know if i can be bothered with the end caps, you can get them at the hardware.
i had to replace the lead because in John's words " it's been got at "
i didn't know you couldn't change the lead, i just took the top off and pulled the old one out and bought a new one the same length and then did some research it turns out that where the lead goes inside there's a little screw gizmo that the lead screws onto.
i had a bit of trouble because the new lead was too big but i got around that, put a bit of silicone around it and screwed it in.
regards, peter
pat777
Re: trolley
Post by pat777 »
Thanks Peter, I thought that model had a sealed ignition unit, it must be a different ignition unit that is sealed and that the lead is not replaceable on.
Does anybody want to chip in which ignition units the leads are easily replaced on and which ones are sealed?
seagull101
Re: trolley
Post by seagull101 »
Wipac MK3 ignitions (which is what you have) can have the lead changed.
Wipac MK4 ignitions (whats on my 1993 ED 102)cannot have the leads changed.
Jacob
pat777
Re: trolley
Post by pat777 »
Thanks Jacob.
Re: trolley
Do SOS offer an exchange service on CDI coils to replace the HT lead. I recall something like that in the past? Have a word with John.
