Amal 416/ 1A
Posted: Sat Oct 28, 2017 7:49 pm
Question - Why does the gravity fed Osprey need a throttle valve stop adjuster screw? Why do the silver century / late 40 model amal carbs not use this and is the 416 / 1 otherwise identical and can the body be drilled and tapped to take one? (I have a 416/ 1A which looked bonny on the outside but inside the bowl was very badly corroded).
