Bayonet cap
seagull101
Bayonet cap
Postby seagull101 » Sun Nov 12, 2017 4:39 pm
Hello everyone,
Is there a way of fixing the vent on my SD bayonet cap so that its straight again? I haven't touched it for fear of damaging it.
I also have a spare chrome bayonet cap that has the same problem but not as bad.
Any ideas?
Jacob
Re: Bayonet cap
Postby Collector Inspector » Mon Nov 13, 2017 8:37 am
I suggest if it still works as intended then leave it be.
Other will chip in as they will know better than me as to how the are assembled in the first place.
Just took a leaflet out of the letterbox, saying that there's no reason I can't have good sex at 65.
Brilliant - because I live at no. 49 so it's not far to walk home afterwards!
Re: Bayonet cap
Postby Oyster 49 » Mon Nov 13, 2017 1:40 pm
I suspect the hole in the diaphragm is worn and the diaphragm is probably worn and distorted. I'd leave it well alone if I were you..
The diaphragm is not flat, so the valve will not sit square and just wobble about. The original is the cap on the right in the photo. The new ones have a flat diaphragm.
Return to “General Topics”
Who is online
Users browsing this forum: No registered users and 18 guests
