FVP5959
seagull101
Re: FVP5959
Postby seagull101 » Wed Mar 14, 2018 6:24 pm
Gannet wrote: But, I do not understand why you cannot use it locally?
Salt water, this will probably wreck it after a few trips.
Gannet
Re: FVP5959
Postby Gannet » Wed Mar 14, 2018 10:37 pm
Jacob,
I think that the idea that that salt water will wreck it after a few trips is completely wrong.
Remember these engines were designed for salt water use. The very fact that so many have survived is testament to that. They were not like cars of the 50s, 60 and 70s which rusted through helped by the occasional dose of winter salt on the roads.
I only use my FV/FVPs in salt water and often for a week or two at a time. They are either on the dinghy transom or on my boat sailing somewhere, and without a fresh water flush during that time. I have detected no corrosion problems whatsoever and am not the slightest bit concerned about them being used in salt water.
There are a few simple things which we can cheaply and easily do, and which will ensure that your FV/FVP will last another 2 or 3 generations of intermittent salt water use. By intermittent, I mean being on a transom most weekends in the summer, as opposed to be left permanently on a boat.
1. As I have already pointed out, the steel plates with their sealant on both sides are there to prevent the cooling water coming into contact with the aluminium head and crankcase. This is absolutely vital.
2. A fresh water flush is critical after use and before storage. A wash down with of the outboard should be carried out then with application of a dewatering fluid ie WD40 and a wipe down with an oily rag.
3. Apply some dewatering fluid or and/or oil into the block via the cooling water outlet. You can see from the two lower studs on your FVP that they have probably remained wet for ages, as they are almost in contact with the bottom of the wet block when stored. Rust preventing fluid is needed there.
4. I apply a zinc marine based white grease to certain parts eg the drive shaft tube and various other parts after flushing. This provides excellent protection in storage and when next used.
5. The FV gearbox should be drained and filled up with SAE140 directly after the engine has been flushed. Contrary to some advice given on this site, the box MUST be completely filled right up with oil when the engine is laid horizontally with the drain plug upwards. Screwing the drain plug in when it is brim full of oil will force the oil up the probably worn bevel pinion bearing, displacing any water there.
6. Good quality paint followed by grease needs to be applied to the drive shaft and the drive shaft tube. All bolts and screws should be assembled with grease.
Doing this and using the outboard, is the best way for you to enjoy it, and to ensure that it survives for years to come.
Go for it!
seagull101
Re: FVP5959
Postby seagull101 » Thu Mar 15, 2018 8:53 pm
I might give it a go but the other problem is that the power from a FV or FVP probably isn't good enough for the wind and waves here as on a calm day the waves can be 1-2 feet tall here. I use a 1975 (i think) FPC on the dinghy which is quite suitable for the weather conditions here, although i will probably try my Model 75 this season. The FPC will definitely have more power than any little 40. The FVP may be ok on a really calm day but not at another time.
More to come on this motor soon.
Still not sure if i should restore it or not, any opinions on this?
Jacob
Re: FVP5959
Postby Keith.P » Thu Mar 15, 2018 9:37 pm
I could give a 102 a run for its money with my FVP, Charles can contest to that, it was on a seagull outing some years ago and I think Charles was on tow again that time.
As Jeremy has stated in the past, some motors are better than others, give them a try you maybe surprised.
Re: FVP5959
Postby Oyster 49 » Thu Mar 15, 2018 10:23 pm
Charles is always on tow :lol: Too highly strung his engines :P
seagull101
Re: FVP5959
Postby seagull101 » Thu Mar 15, 2018 10:27 pm
:lol: :lol:
Return to “General Topics”
Who is online
Users browsing this forum: No registered users and 23 guests
