One more
One more
Fvp10693
Next project :lol:
Re: One more
Looks pretty much intacked other than wrong gearbox
Re: One more
How many have you now?
Re: One more
At a quess 6 and another still to come need to check out the time capsule :lol:
Re: One more
Going to need a wide transom boat.... that will be fun.
Re: One more
Very little use or stored up for a long time came apart easily
Check out that head best I've ever seen all brushed down with petrol before polish..
Gannet
Re: One more
Post by Gannet »
Tam,
That looks a really nice original ( as you say except for the gearbox) little used example.
Its interesting that lots of these later FVPs have the canted oval tanks. Perhaps, as its basically the same shape as the contemporary LS tank, that it might have been an original option or the standard fitment. What do you think Tam?
The flywheel date looks like 5/52, which would be about right. Have I read that correctly?
The carb spec interests me. Could you tell me:-
1.Has the bowl got a drain hole near the top? 2. Has the choke shutter got a hole? 3. Has the carb got a throttle stop?
Its nice to see the transom security bar appears to be the early 'L' shaped nickel plated flattened end type. Is the transom bracket a 4" one, or the later 5.4" one?
Sorry for all the questions!
Cheers,
Re: One more
Spot on Jeremy flywheel 52
Drain hole on carb
Choke shutter unholed
Carb has throttle stop
Regarding transom I'll measure when home
Regards TAM
Re: One more
:lol: the weekend is here :lol: Willie on the wireless a single Malt and the fun begins
Re: One more
shiny! 8)
Gannet
Re: One more
Post by Gannet »
That looks good. Is it for FVP10693 or for FV2923?
I think the FVs are excellent Seagulls for small dinghies. last week I spent 5 days messing around on the Yealm estuary in South Devon with FV1867T on the back of a 9 foot dinghy. The small round tanks need filling up quite often!
Re: One more
10639 will be getting this tank Jeremy i have another one in the oven this evening cheers
Gannet
Re: One more
Post by Gannet »
Hi Tam,
Thanks for the info on FVP10693. It all helps to establish the probable correct spec, especially with data from a little used and possibly not previously rebuilt unit.
You mention putting the tank in the oven. Is that to bake the paint?
Did you see in the news that a bottle of a 1926 Macallan single malt fetched £813,000 !!!
Does one drink it, or just look at it, or just hope it is worth more next year?
Bottoms up!
