Seagull SD restored
mauriziopiras
Seagull SD restored
Post by mauriziopiras »
Hi guys,
Let me show you my SD Navy type just restored :P
Maurizio
Navigare necesse est, vivere non necesse
Re: Seagull SD restored
Very nicely done and honest looking....
Almost there, very nice!
But no Chrome or Nickel on the coppertop SD!
Get the fuel cap, fuel pipe & the water pipes & fittings stripped, replace the fuel tap with a push, standard brass one, John has the much more correct brass L shaped transom screws, & the drive shaft tube needs re-plating with dull,none shiny Zinc.
Your big brass washers on the waterpump housing look a bit alien.
mauriziopiras
Hi Charles, thanks for the tips. As soon as I find the original components, I will replace the wrong parts.
Maurizio
Any chrome plater will strip those components, plenty of brass fuel taps about, looks nice!
Nice job! The original tanks were steel of course, but hard to find now. A nicely restored SD is one of my favourite engines 8)
Take another look at the fuel pipe shaping also.
A bit of inspiration to get back in to my SD.
Thanks for sharing Maurizio.
Sandro Picchio
Post by Sandro Picchio »
Bel lavoro! - nice job!
Sandro
Very nice. Any chance l can get the magneto JM number? And the last digit of the engine number? Thanks.
mauriziopiras
Hi there Hugz,
I will provide you with JM number for your register in a couple of days as I left the SD in another town.
Maurizio
Wonderful! Thanks. I jave 50 now.
Doing well there Hugz :P
mauriziopiras
Excellent Hugz. I will post a new SD with brass carb you can add to your register soon.
Maurizio
