Buyer beware!
Buyer beware!
Postby Oyster 49 » Sat Sep 22, 2018 12:48 pm
Came across this earlier. SD cylinder attached to a later crankcase and the serial number removed, with dodgy restamped number. Im surprised the seller has not at least pointed out the crancases are not original.
https://rover.ebay.com/rover/0/0/0?mpre ... 3446399842
Re: Buyer beware!
Postby tambikeboy » Sat Sep 22, 2018 2:33 pm
From a good seller too ....strange
Re: Buyer beware!
Postby Charles uk » Sat Sep 22, 2018 3:47 pm
You might be being a little bit harsh, as that appears to be a Seagull made replacement SD crankcase.
Which would you prefer original crankcase with tired main bearings or a replacement that probably has done much less work?
Your right Tam, I've had bits from him, accurately described, & no problems, reasonable price & not blasted.
Re: Buyer beware!
Postby Oyster 49 » Sat Sep 22, 2018 11:28 pm
I’d expect the seller to point out that the crankcases are not original he will know this.
I’ve also had parts from this seller.
Return to “General Topics”
Who is online
Users browsing this forum: No registered users and 11 guests
