Forty Feather
Re: Forty Feather
Does your Mk4 have a stop button wire Martin?
- fleetingcontact
Re: Forty Feather
So the stop switch is something to do with grounding the signal to the CDi right? Make with the science dude. Yep, the module I referred to has the requisite wire.
- fleetingcontact
Re: Forty Feather
Mk4 CDi module
Mk3&4 nut, washer, pulley, spacer
Mk4 module with extra wire
Mk4 Flywheel
Re: Forty Feather
If you put your motor back together with that wire hanging through one of the holes in the base plate, start it & see what happens when you earth that cable on the motor.
Your picture of the Mk4 flywheel & spacer is missing the locking pin that fits in both holes to stop the spacer spinning when the recoil is pulled, between the starter cup & spacer they rely on the aluminium binding under the nut pressure.
- fleetingcontact
- fleetingcontact
Re: Forty Feather
I know, just for fun, why don't you stop asking all your annoying rhetorical questions and actually contribute something for a change?
Re: Forty Feather
The other option of course, would be to change the throttle control for a spring loaded trigger type, normally used on strimmer etc, so if I let go, as in if I fell off kayak , it would cut out the seagul as it was meant to, if that makes sense
Re: Forty Feather
Bit rude, have you ever taken one of these apart yourself?fleetingcontact wrote:I know, just for fun, why don't you stop asking all your annoying rhetorical questions and actually contribute something for a change?
Re: Forty Feather
You can get a twistgrip throttle that fits Adjust the throttle so that it shuts off if you let go.Steve On sheppey wrote:The other option of course, would be to change the throttle control for a spring loaded trigger type, normally used on strimmer etc, so if I let go, as in if I fell off kayak , it would cut out the seagul as it was meant to, if that makes sense
- fleetingcontact
Re: Forty Feather
Nothing rude about it.Horsley-Anarak wrote:Bit rude, have you ever taken one of these apart yourself?fleetingcontact wrote:I know, just for fun, why don't you stop asking all your annoying rhetorical questions and actually contribute something for a change?
Yes, I have taken several apart (and put them back together), it was never easy and involved much 'ungentlemanly behaviour'. Nor was a subsequent removal of the flywheel much easier.
The throttle idea is very sensible. Pattern Enfield 7/8" twist-grips made in India can be had via Ebay for cheaper than elsewhere.
https://www.ebay.co.uk/itm/Twist-Thrott ... ctupt=true
Re: Forty Feather
As a newbie, any links to video showing me how to do that ?Charles uk wrote:
Replace the gear oil ever time you use it!
Re: Forty Feather
Don't worry, found it on YouTube
Re: Forty Feather
Not that keen on the "Dead man's throttle arrangement" as you loose a hand for any of the routine jobs & if you have to do anything in a rush that requires 2 hands, the engine stops!
I think the lanyard idea is the best course of action. get us a picture of the flywheel rim & I'll be able to tell you if this is an easy job that only requires a switch that costs less than £10 from Ebay, just ensure it's waterproof.
If you have any doubts about the reason why, next time your out in your Seagull boat sit down & let go of the tiller at full throttle!
Give your flywheel taper interface a small squirt of WD40 or the like, this will involve removing the nut, starter cup & spacer, & follow Seagull's instructions on how to remove the flywheel, it's not usually a drama 9 out of 10 times, Just make sure the hammer hits the nut firmly & dead square, it's probably better that the 4 hands doing this are male!
I know I've got a reconditioned Mk3 with a stop button in storage I'll try & get a picture this afternoon.
Re: Forty Feather
I already have the lanyard kill switch, but must admit to being a bit of a dexter, the tiller will probably get removed as not needed, the engine will be fixed in straight position, as my trident has a rudder fitted on the rear with foot controls for turning, I may even be able to set a lanyard onto the throttle, so it can be set at a pre determined speed and let go off, but still cut out if I leave the kayak unexpectedlyCharles uk wrote: If you have any doubts about the reason why, next time your out in your Seagull boat sit down & let go of the tiller at full throttle!
Re: Forty Feather
Just had a dexter thought which I'll try out first, as I'm sure if I was to fall out, it'll be from opposite side to the seagull, as the seagull side will also have an outrigger,
So my cheap easier cut out, will be to drill the knob on end of throttle, and place a ring with lanyard attached to me, still keep both hands free and original fittings
