wanted the brass bolt and thumb screw that the tiller mounts
wanted the solid brass bolt and thumb screw that the tiller mounts onto for an early 102...cheers
Hi, I've got a large supply of NOS Tiller Arm Studs (P/N 1347) in brass and steel (for SD). Also the original P/N 1350 Rubber Sleeves, P/N 1348 Friction Washers, P/N 1349 Steel Plain Washers (for SD) and many other NOS early 102 parts on stock. Unfortunately I don't have the Wing Nuts on stock (does anybody knows a good supplier for the Wing Nuts?).
I will swop for other BS parts or sell for fair prices.
Br, Jan
Br, Jan
