Fuel fitting
Post your wanted adds here
seagull101
Fuel fitting
Postby seagull101 » Sun Oct 22, 2017 4:15 pm
I'm after the fuel fitting that goes underneath an ewarts fuel tap. Need this for my 418 carb.
I have plenty of rubber pipe and the banjo fitting but just need the part on the other end of the pipe.
Cheers, Jacob
Re: Fuel fitting
Postby Keith.P » Sun Oct 22, 2017 7:08 pm
You just need an old fuel pipe and pull the end off one.
seagull101
Re: Fuel fitting
Postby seagull101 » Sun Oct 22, 2017 8:43 pm
Yeah i do have a few but its a shame to destroy a good hose, annoyingly i threw away a snapped one last week!
Re: Fuel fitting
Postby Keith.P » Sun Oct 22, 2017 8:49 pm
I threw away a snapped one last week!
Normally if you keep something, you will never need it, until the day after you throw it away, its called sods law.
RickUK
Re: Fuel fitting
Postby RickUK » Mon Oct 23, 2017 11:15 am
HI Jacob,
what you need is a petrol tap as fitted to the later plastic tanks, where the top 3/4 is like a standard Seagull tap, but instead of a threaded bottom end, it just has a pipe spigot over which the pipe pushes. Some illustrations show a plastic 'laboratory' clamp to nip the pipe onto the spigot, but normally a metal pinch clip (can't remember the proper name) is a more permanent fix.
John should be able to help you wit the correct tap, and I know he has the pinch clips I mention, but if not let me know, and I should be be able to find one.
Rick
seagull101
Re: Fuel fitting
Postby seagull101 » Mon Oct 23, 2017 7:06 pm
Trouble with that is that if i use an 'o' clip then i would have to drain all the fuel just to change the fuel pipe or even clean it out.
What i might do is take the top part of a century water pipe then just push the rubber pipe over that.
I would still have to find the correct nut though as a water pipe one is a 5/16 head but a fuel pipe one is a 1/4 head.
Jacob
RickUK
Re: Fuel fitting
Postby RickUK » Tue Oct 24, 2017 4:04 pm
would you need to disconnect the pipe that often? The other thing you could do is to use a petrol pipe clip (like a much lighter version of a jubilee clip, and just loosen it and pull the pipe off as necessary.
Return to “Wanted”
Who is online
Users browsing this forum: No registered users and 1 guest
