2 stroke oil
Jim bow
2 stroke oil
Post by Jim bow »
I can't get my 'gull started. Before I start taking things apart, I need to know of there's a specific oil to mix with the petrol. I used Valvoline TC-W3 2 stroke oil.
Is that acceptable? The gas/oil mixture os a very dark colour.
1charan
Re: 2 stroke oil
Post by 1charan »
Your oil is correct. TCW3 is the right oil for outboards.
How old is the petrol? Fresh petrol has more volatile parts and starts better.
How much oil did you use in the petrol? And is this the correct mixture for your Seagull/carburettor?
Jim bow
Re: 2 stroke oil
Post by Jim bow »
Fresh fuel, 10 to 1
Vic
Re: 2 stroke oil
Post by Vic »
Jim bow wrote:Fresh fuel, 10 to 1
10:1 is correct for a 1974 40+ unless modified to run on 25:1. See SOS website for details and identification of the alternative needle.
I am surprised the fuel mixture is dark in colour unless the oil is very dark. If the oil is not highly coloured your fuel is contaminated
Vic
Re: 2 stroke oil
Post by Vic »
deleted... due to duplication
Re: 2 stroke oil
If your engine won't start, then you need to go back tobasics. have you got a spark, and is fuel being delivered? check your ignition system first then start working back through the fuel system, for cleanliness, blockages etc. Fresh fuel should be part of this.
a seagull in good order should start within 2-3 pulls if all is well. I suspect the main reason for poor starting is a dirty plug or closed up or dirty points.
