FVP5959
seagull101
FVP5959
Postby seagull101 » Sat Mar 10, 2018 9:09 pm
As promised, here are they pics and stuff for my FVP.
So far today i have stripped it down to investigate as it was seized solid when i got it. I removed the carb then sadly noticed a crack in the block :x
I kept stripping it down to the point when the carb, tank, head and gearbox was off. I gripped the flywheel in two hands and with little struggle it popped free and span over nice (i did all this with oil in the bore). This is as far as i got today but will continue further tomorrow in removing the cracked block and fitting the spare i have,will also change the studs for spares i have.
The magneto is also ok so thats good.
Jacob
Re: FVP5959
Postby tambikeboy » Sat Mar 10, 2018 9:25 pm
Nice find china looks like you'll be having fun with your new addition....
seagull101
Re: FVP5959
Postby seagull101 » Sat Mar 10, 2018 10:57 pm
Cheers tam, still not sure if i should restore it or not,one of the FV's are 100% getting restored the other is a 1 owner motor so will stay original.
Jacob
Re: FVP5959
Postby Oyster 49 » Sat Mar 10, 2018 10:59 pm
I’ve not seen a cracked block on a little forty before, plenty of corroded studs and crankcases!
Re: FVP5959
Postby Keith.P » Sun Mar 11, 2018 1:14 am
Blocks are not that hard to find, hopefully it can get put right, just a fuel pipe and grip, it will be good as new again.
Re: FVP5959
Postby Hugz » Sun Mar 11, 2018 1:51 am
I need to get a grip too!
seagull101
Re: FVP5959
Postby seagull101 » Sun Mar 11, 2018 11:07 am
I have a grip here, but it has turned white and i'm not sure if painting it will look bad.
Can you make the fuel pipes for these?
Jacob
Re: FVP5959
Postby Keith.P » Sun Mar 11, 2018 11:54 am
If you have the tools, then yes you could make one, I would say it will be the pigs ear style one.
seagull101
Re: FVP5959
Postby seagull101 » Sun Mar 11, 2018 1:58 pm
Got it pretty much all stripped down today except the gearbox which i will do later. The block fell apart some more while getting it off and the studs will need replacing.
seagull101
Re: FVP5959
Postby seagull101 » Sun Mar 11, 2018 9:19 pm
Here are The two FV's that came with the FVP. Shiny tank one is FV8905 and will be fully restored at some point. The other is FV15020 and is a 1 owner motor before me and will stay original as its pretty good condition with tank decal still on it.
Re: FVP5959
Postby Nudge » Mon Mar 12, 2018 5:10 am
Do you think the block was broken due to rust or has the engine been dropped at some point?
seagull101
Re: FVP5959
Postby seagull101 » Mon Mar 12, 2018 9:00 am
It was definitely by rust because after those large bits of block fell off the long stud was corroded solid into the block. It took me a few hours to chisel out all the rust with a small screwdriver and hammer.
Gannet
Re: FVP5959
Postby Gannet » Tue Mar 13, 2018 10:43 am
Great collection of early 40 series, Jacob. Well done!
Cracked blocks are not that common, but it does happen - I have a couple.
Is there any significant corrosion of the crankcase? Don't forget that the most significant point of the steel plates is to prevent water being in contact with the aluminium crankcase or the cylinder head. That is why originally they were treated very liberally with a black plastic sealant on both sides and the stud holes are a tight fit around the studs. Electolytic corrosion will occur if water gets to the aluminium. My belief is that once these engines left BS, this design feature was not understood by most subsequent rebuilders and aluminium corrosion was the result.
I know that you are aware that the clamp bolt pump housing (CBPH) is the wrong one for FVP5959, as the drive shaft tube should screw in. I possibly have a correct spare housing and tube. Yes, from my data sheet, you can see that the looped fuel pipe is the correct one for 5959, with the change to the U shaped one being made in the mid 8000 serial numbers. Is the carb the correct one?
Well done for taking on the repair/restoration of these early 40s. They are the very best Seagulls! Although I might be a little bit biased!
If you need any help or bits, you have my telephone number.
seagull101
Re: FVP5959
Postby seagull101 » Tue Mar 13, 2018 10:44 pm
Jeremy,
The corrosion on the head and crankcases arent bad probably 1-2mm deep at the most and since i cant really use it locally it wont see much use so i wont worry about the corrosion. I have a few of the steel plates and will be refitting them with sealant.
I am aware of the incorrect pump housing and tube but thanks too the boss man Tam, thanks mate! I have one in the post for it.
Do you have a spare fuel pipe about Jeremy? PM me if so as it would save me making one.
Jacob
Gannet
Re: FVP5959
Postby Gannet » Tue Mar 13, 2018 10:56 pm
Jacob,
It is good news that there is only a bit of corrosion. What also helps to prevent corrosion of the crankcase faces is to paint them with a chromate paint designed for aluminium. But, I do not understand why you cannot use it locally?
That is great that Tam, is able to get a threaded pump housing and drive shaft tube for you.
I am afraid I do not have any spare fuel pipes, either looped for FVP5959, or the U shaped ones for the later FV/FVPs.
Return to “General Topics”
Who is online
Users browsing this forum: No registered users and 22 guests
