Came across this earlier. SD cylinder attached to a later crankcase and the serial number removed, with dodgy restamped number. Im surprised the seller has not at least pointed out the crancases are not original.
https://rover.ebay.com/rover/0/0/0?mpre ... 3446399842
Buyer beware!
Buyer beware!
Re: Buyer beware!
From a good seller too ....strange
Re: Buyer beware!
You might be being a little bit harsh, as that appears to be a Seagull made replacement SD crankcase.
Which would you prefer original crankcase with tired main bearings or a replacement that probably has done much less work?
Your right Tam, I've had bits from him, accurately described, & no problems, reasonable price & not blasted.
Re: Buyer beware!
I’d expect the seller to point out that the crankcases are not original he will know this.
I’ve also had parts from this seller.
