Stuart P55MR
Re: Stuart P55MR
Great attention to detail here, very interesting read 8)
Re: Stuart P55MR
Thank you Oyster.
I don't have the tools or the experience Nudge. The new seals may be less interesting, but I expect they will provide better overall performance.
Anyway, back now to where I was a week or so ago, however this time with both shaft seals and gearbox drive seal replaced, a few other components fitted and some issues sorted along the way.
For the benefit of those contemplating replacement of seals in Sturt Turner P5, P55, P6, P66 Marine Engines (and probably other models as well), the following pics and notes will be of assistance. Needless to say, reverse order applies for removal.
Replacement seal (type SC 200 112 37 TTEO 23 4) fitted to rear crank case housing.
Magneto/Waterpump drive sprocket installed on shaft. Note locating pin.
Spacer installed on to shaft.
Fit chain to sprocket. Secure with wire or similar at upper end, until ready to install the Magneto drive assembly.
Fit external bearing retainer. Comprises a recessed flat section at rear side to facilitate correct alignment. Secure into position with washers & screws (2). Note bearing faces out to clutch cone. Take care when removing/fitting this bearing. It will fall apart but is easily reassembled.
Fit shaft keys (2), clutch cone and secure with nut. An 11/16BSF or 5/8BSW tube spanner is required.
I forgot to photograph the replacement of forward shaft seal, however this is a much more straight forward process. Remove forward crank case assembly. remove bearing from shaft. Remove old seal and collet. Clean and lubricate all. Refit collet. Fit seal. Fit bearing. Refit forward crank case section.
All above is well worth doing in my humble opinion. Only real problem is sourcing a suitable tube spanner ie as without removing the clutch cone access, the crank shaft cannot be removed from the rear crank case section. Small investment for big gains. Expect to pay around $10 Australian for the crank shaft seals (2) and the gearbox seal (type HSU JAU HJ 801098 TC 1.437 2.250 0.375, not shown here), grease nipples and a couple of circlips.
Here she is again, this time with control column and magneto drive in place.
All bright hardware will be painted over per original in due course.
Re: Stuart P55MR
Gearbox has been coupled to the engine. It engages forward and reverse and transitions through neutral along the way. Reverse and back to neutral requires additional force albeit that the eccentric at the base of the control column has been adjusted for optimum performance in accordance with the manual. I suspect cause to be lack of oil in the gearbox, however until the sump plugs are polished and fitted and the gearbox has been correctly filled with SAE30, I won’t know for sure. Excuse the image quality.
Next step will be sourcing alternative head gasket material (I don’t want to use copper again), making the head gasket and fitting the cylinders/expansion chamber and head.
I’m in absolutely no hurry to complete, as there are many other projects to keep me busy in the meantime.
Re: Stuart P55MR
Things like this can only inspire others and help to keep the scene going. Great work in sharing 8) You are not really going to paint over that nice brass and copper are you?
Re: Stuart P55MR
How does the timing chain get lubed, now you've replaced the "seal" that permitted oil through, but with very little crankcase compression loss, with an lube tight nitrile oil seal?
Or is there an external oil nipple fitted?
Re: Stuart P55MR
Oyster 49 wrote:Things like this can only inspire others and help to keep the scene going. Great work in sharing 8) You are not really going to paint over that nice brass and copper are you?
Hello Oyster,
Thanks again for the kind words.
I probably should have been a little clearer in my above post. Only the steel fasteners will be painted over. Brass and copper will be polished ie with the exception of 3 only brass components which I felt looked a little out of place unpainted.
Re: Stuart P55MR
Charles uk wrote:How does the timing chain get lubed, now you've replaced the "seal" that permitted oil through, but with very little crankcase compression loss, with an lube tight nitrile oil seal?
G’day Charles,
The timing chain is housed within what is essentially an extension of the gearbox housing, which is of course is semi filled with gear oil.
It’s too late now to get a photo of the sprocket, chain and dip stick together, but I will attempt to take some measurements just to see how all line up. This is I'm sure lubrication is caused by the splashing of oil from other rotating parts when the engine is cranked by hand and in operation.
The change in seal type is discussed in the Stuart Turner section of Oldmarineengine.com. There are also several ‘in service’ and ‘running display’ ST’s in Australia with the same seal mods. Had that information not been available, I would have been reluctant to change from the original seals.
Thanks & regards,
Re: Stuart P55MR
Another small step forward with the Stuart over the weekend.
The original plan was not to proceed to this stage before all the brass dome nuts etc had been properly polished and clear coated, but I’ve been struggling with motivation to do that.
So the plan now is to pick up some more BSF nuts and washer during the week and use those to temporarily replace the brass dome nuts until the polishing of those has been completed.
PS: Gasket material chosen is 1mm thick Klingersil C4430 rated at approx. 430C and bedded down Locktite 515. Not the easiest of materials to work with and clearly over the top for this application, but I’m happy with it.
Re: Stuart P55MR
May 1950 Seacraft Magazine
Dec 1949
Re: Stuart P55MR
Thanks for that Hugz,
You are a true gentleman!
I'll get around to finishing the Stuart one day. Just needs the Water Pump & Carby polished and refitted.
