Little Forty F341
Jan
Re: Little Forty F341
Post by Jan »
Thanks for the offer Oyster but I prefer the standard FV type gearbox on F341.
One day I will find one or I buy a parts motor.
I know it will be a long term restoration.
Jan
Gannet
Post by Gannet »
Jan,
Its great to see F341 coming back to life.
My F201, which is complete and going so I have chickened out of taking it apart, does not appear to have a steel crankcase gasket. The gasket appears to be made of some white composition. I have no idea of course whether it left the factory in that state.
As you would expect it has a bronze rotor around the thinner section drive shaft.
The gearbox, as you know, is a standard FV one. Although F201's prop is slightly smaller in area (than FVs) and runs directly on the propshaft ie there is no bronze bush.
Cheers,
Jan
Post by Jan »
Hi Jeremy,
F341 had an original paper cylinder base gasket but the head gasket was a non original thick and sticky mess of kit, sealant, asbestos and paper.
I must find some material I can use as head gasket.
They fitted the later plastic and larger model 40 impeller so I need also the small bronze impeller.
Luckily the F prop is in good shape and already polished.
Your right, it doesn't have the bronze bushing and the F prop is smaller comparing the FV prop.
I never noticed the difference.
Jan
