Opening a 102 gearbox
- Shearwater
I'm still working on the restauration of my 102. Now I'm facing a dilemma. I can't get the end cap off. I would like to see if everything is ok inside. I tried a bit of hammering on the prop shaft but that doesn't work. Peeking through the oil filling hole shows no problems, everything is running smooth and I flushed it a while ago to get all old oil etc out. What do you think: should I leave it as it is and fill it with new oil, ore should I try harder to get the end cap off. And how? Harder hammering, heating?
Re: Opening a 102 gearbox
If all feels OK then do not get too stressed.
It's probably a good idea to remove it and clean all the sludge out, as well as getting the gears nice and clean. That said I ve often found a cleaned box to be more prone to leakage
The end cap will have stuck in place with a combination of corrosion and possibly old gasket goo. Apply some gentle heat all around and tap the lugs gently with a plastic or wooden mallet to allow the end cap to rotate. Do it in both directions and it should soon loosen. Once off give the whole thing a really good clean and you are good to go.
I've got a SD box to look at at some point that needs the pinion replacing.Thats going to be a right job I suspect.
Yep, if needs pulling apart relax.
Lots of help here aye!
Some pics would be cool...................We All Love Pics!
Drain the contents of the gearbox first.
Remove the brass collar on the drive shaft and the 2 or 3 screws on the front cover.
Find something to place in the slot where the drive spring sits, heat the front cover and outer edge of the gear case and with a rubber or wooden mallet, hit quite hard on the end of the shaft.
Always works for me.
