Amal 416/ 1A
Arbian
Amal 416/ 1A
Postby Arbian » Sat Oct 28, 2017 7:49 pm
Question - Why does the gravity fed Osprey need a throttle valve stop adjuster screw? Why do the silver century / late 40 model amal carbs not use this and is the 416 / 1 otherwise identical and can the body be drilled and tapped to take one? (I have a 416/ 1A which looked bonny on the outside but inside the bowl was very badly corroded).
Re: Amal 416/ 1A
Postby Charles uk » Sat Oct 28, 2017 8:22 pm
The Osprey has a stop button to cut the motor, so has a screw to set tickover, so that it doesn't stall during use.
You could manage without this ability, try and see, use the osprey main jet.
Return to “General Topics”
Who is online
Users browsing this forum: No registered users and 27 guests
