Wanted Silver Century Cylinder Block
- seagullsaver
Hi All,
Does anyone have a good cylinder block for a Silver Century ??
Mine is suffering from terminal cracks.
Many Thanks
Many Thanks
- The Tinker
Re: Wanted Silver Century Cylinder Block
If the cracks are in the outer castings around the water jackets it is possible to seal them up with solder if you are careful
- seagullsaver
Thanks for the reply but unfortunatly one of the cracks is across the exhaust port and is full depth.
Pity because the bore is perfect.
Have you tried John at SOS? He maintains a large stock of parts.
- seagullsaver
Still wanted
Got one somewhere - let me have a root around this weekend. Whereabouts in the country/world are you?
- seagullsaver
you have a pm
Thanks
Thanks
- seagullsaver
Hi Rick
I'm not sure that pm's are working for me
Did you manage to find a block ??
Thanks
Thanks
HellO john - it had to be the weekend befroe I ahas a chence to lok for one - anyway, have found one. Got your pms, so I assume they are working OK - will reply the same way. Rick
- seagullsaver
Hi Rick,
The block arrived today its in perfect condition,
Many thanks for helping me out hope I can do the same for you sometime.
Hi John - thanks for the note - took a time to get to you - posted it last Saturday - must be Christmas! Rick
