Villiers jet numbering or size
- 1650bullet
I have 2 villiers carb jets that have different numbers on them. On the top face of the jet (The part were the carb slide sits and were the jet needle goes threw) One number reads M8J and the other reads M9O Which one is the seagull jet.
Re: Villiers jet numbering or size
M9O in both my Seagulls
R8J in the lawnmower , Villiers Mk 2 Midget.( should be M7J according to the parts list.)
M8J is listed for the Mk 3 Midget
Any idea what the differences are?
- 1650bullet
Vic wrote:M9O in both my Seagulls
M90 is the one i need then, Thank you vic. Ive taken the carby of my 40-plus to use on my nieghbours 40-plus to get it going. Im then going to pick up some parts from chris this coming friday to replace mine. The other jet is from a villiers reel mower carb.
M8&7J are both found in seagulls too. So no answer except what's runs the best. Cut and try.
Cheers Rolf.
www.acmeengineering.com.au
www.rolfhey.com
www.rolfhey.com
