Seagull 40 plus 1986 model with cdi ignition
doctorbob
Post by doctorbob »
Seagull 40 plus 1986 model with cdi ignition[,The cdi unit has failed ,can i fit a wipac mk2 complete ignition system ,as a replacement,or is the key way in the crankshaft incorrect for mk 2 system
The mk 3 flywheel has 2 keyway settings ,one position for 40 range , and another position for the centry engine,
The mk 2 wipac flywheel only has one keyway
has anyone overcome this issue
Re: Seagull 40 plus 1986 model with cdi ignition
John Williams is able to get your CDI repaired.
doctorbob
Post by doctorbob »
Any idea on costing on such a item
It might be best to ask him at Saving old Seagulls.
