New to gulls looking for advice.
Re: New to gulls looking for advice.
nice
VERY NICE
old skool or olds cool, just like me! :lol:
102's you gotta love'em
Stelios_Rjk
Post by Stelios_Rjk »
Goood! I like you work!
fergalb
Post by fergalb »
Thanks Guy's :D just about finished now except for the thrust block and a bit of adjusting here and there.
And here is a little video of her first start up, a bit smokey at first but not too bad once she got going :D
https://www.youtube.com/watch?v=rO_K2MiZRRE
My crackerbox powerboat build http://player.vimeo.com/video/87412648
http://www.youtube.com/watch?v=BfNjkhMRt40
1958 Evinrude restoration http://www.boards.ie/vbulletin/showt...php?p=77361131
Very nice job! Whats next?
just one teencey weencey little thing wrong here!
FERGAL, move the exhaust clamp at the top of the exhaust tube 180 degrees so that the bolt sits between the torque tube and exhaust tube, that way the motor won't suddenly jump into gear?
the idea is that the clutch rod will sit on top of the flat section of the clamp and cannot drop down until sideways and up movement on the clutch lever is imposed.
(took me a while to work that one out but does leave scratch marks on the clamp and exhaust tube but works a treat)
still not sure about the fuel tap though!
as long as you like it, thats all that matters.
as before, nice, VERY NICE
enjoy it :D
To slow posting :D
Looks good, nice job.
Two points, if you turn the top exhaust clamp, so that the bolt is under the cylinder it will hold in gear, as its trying to hold on the rounder part of the clamp at the moment.
Second, I would put a couple of split pins in the drive tube transom mount as you may end up with a nice transom on a boat but no outboard.
Next project ?
fergalb
Post by fergalb »
Thanks all tips welcome :D The tap may go yet as soon as I get a bit of pipe.
Wow... wonderful! You have done this before. Would the fuel tap under the bowl be for an auxiliary tank? Original exhaust tube taken down to brass?
Keith.P wrote:Second, I would put a couple of split pins in the drive tube transom mount as you may end up with a nice transom on a boat but no outboard.
Trouble being that doesn't stop the stud coming loose which seems to happen to me half the time....locktite?
Oyster, you have some serious competition in front of you :D
Very Well Done!
I like the Extra additions.
Additions should be something to aspire to.
Very 8) your motor!
haventaclue
Post by haventaclue »
:mrgreen: :mrgreen:
Michael
Post by Michael »
Hugz,
Re the drive tube mount. Not that I ever have a problem with the studs coming out, salt water takes care of that. What I do though is run a seizing wire through one stud to the other. Then they can't back out and th nuts can't come off.
Michael
Post by Michael »
Fergal,
Very nice restoration, well done. Would seem a shame to get it wet.
fergalb
Post by fergalb »
Thanks guy's :D I hope I don't have to get it wet myself as she will only be used as a backup engine. I'm bidding on this bracket at the moment http://www.ebay.com/itm/281368030956?ss ... 1423.l2648 as I like the fact that you can have just a small plate left on the transom instead of the bracket.
I used the newer type on the other boat I built and it looked ok.
Stelios_Rjk
Astonishing restoration!!! I enjoyed the pictures before and after :D :D :D
A nice looking Merc 400, Even though I don't think its as old as its trying to look. :wink:
