170 RPM
rosbullterier
170 RPM
I think I am correct that the Century runs up to 3800 to 4000 RPM, but what about the 170? Overevving seems to be its downfall and I would like to experiment with other ratio gearboxes and props. ( after the new bronze end cap is fitted) . . .
What you can rev it up to depends on the condition of your 170.
With my race 170 I throttled back at Easter, if the revs exceeded 6500 , as I needed to finish, if I wanted to finish first,
With an ok 170 on the back of a 12 foot plus non racing hull I would guess 4000 to 4500 revs should be good.
If it won't do that, it sounds ready for the skip or a good once over.
With a bronze end cap it would all depend on the quality of the engineering.
rosbullterier
Thank you Charles - don't forget I shall have your revcounter attached. Although modifying the engine to improve performance is beyond my remit (or capability) I would like to check how propellors pitch will affect the revs and therefore wanted to know where to start from. I'm using a 1:2.5 gearbox. The bronze bigend cap will hopefully be as well ventilated to the petroil as the original.
