FVP
Post your wanted adds here
FVP
Just putting it out there: I'm after a throttle lever and prop to for an SVP and also SD box with stamp. Thanks.
Re: FVP
Morning Hugo, I have a SD box with ministry stamp. The pinion bearing is worn though, but l also have a replacement pinion bearing to install, to bring it back to good order.
Re: FVP
Wonderful Oyster! I'll pm you....
Re: FVP
Hi Hugu, only snag is that I'm away working until the end of the month.
Re: FVP
No snag at all, I'm in no rush :)
Re: FVP
Cool, check your pm!
Re: FVP
Whoopee! Just found villiersparts has the correct throttle for my FVP
Can anyone do better than 17pounds? Rather keep money circulating within gullland :shock:
http://www.villiersparts.co.uk/cable.html
Re: FVP
Is it on the way?
Nice to get a user revue on this Hugo when you can Aye.
Re: FVP
Post by Adrian Dale »
I have hade really good service from George at Villiers. John at SOS also recommends him. Don't expect much small talk though.. man of few words.
Re: FVP
Yes I have had decent service too. Ask a question and usually a quick reply and to the point. One thing I have noted about villiers parts is that I have asked about parts and seem to get different prices quoted at different times. That said I am happy to use again.
Re: FVP
I've used George before and will again. You may not get exactly what you are after but you will get something that works. I haven't ordered the lever yet as now I know where I can get one the pressure is off plus I need a few JM coils etc.
