An FVP in USA
water bug
Re: An FVP in USA
Post by water bug »
BnC , Thank you for the cable note. I will tyr John at SOS for a short one. And thanks for the spool drawing. Will make the next one to these dimensions. WB
PS: I will try the PM Process. Is Jeremy the keeper of the FVP listing?
Re: An FVP in USA
Yes Art.
Jeremy is the keeper of F,FV,FVP,LM and LS information. Anything you need to know, Jeremy's your man. :P
(i keep all the 102 stuff ) I noticed a 102 in your pics?
Re: An FVP in USA
I better come up with a data sheet, then I can be an expert. :roll: :lol:
Re: An FVP in USA
Trust me Keith, you DO NOT want to be doing that.
You do well enough on your own without any outside influences for distraction!
happy new year to all
Re: An FVP in USA
Art,if you take a look at this link, you will see all of Jeremy's researches so far. It's a really good resource to understand the ins and outs of these particular engines.
http://www.saving-old-seagulls.co.uk/i_ ... _forty.htm
water bug
Re: An FVP in USA
Post by water bug »
Tambikeboy, I sent a PM asking about the screwed transmission tube and water pump housing, When you get home.......
Also as you said , Pictures of the two piece Sparking plug cover would be very helpful. ANY ideas where the brown tubing can be had? Thanks. WB
water bug
Re: An FVP in USA
Post by water bug »
Please someone tell me about what year or what serial number the design was changed from screwed transmission tube into the water pump housing, to pinch bolt. That is on FVP or LS Models . Mine is currently a pinch bolt and considering the need to change to screwed. Thank you all. WB
Re: An FVP in USA
Art, the change to the clamped housing is listed on Jeremys data sheets. See the link I posted above. Approx serial number LS24100.
Re: An FVP in USA
Oyster I don't think his crankcase has a serial number.
Re: An FVP in USA
FVP6343 from the original post. Well within screw on water pump housing range.
Re: An FVP in USA
Oops! sorry.
water bug
Re: An FVP in USA
Post by water bug »
Oyster, Thank you. I looked in Jeremy ' s data but did not find the transmission tube change over. The FVP is the number quoted. So I will need the screwed trans tube.
I do have an LS with no crank case number that I also plan to bring back to life. That one will also need a screwed transmission tube. Too bad , as I do have a pinch bolt one in good condition. These are just what I need for winter projects. Cheers WB
Grumpy
Re: An FVP in USA
Post by Grumpy »
Very nice very very nice.
But the crossbeam on the trolley is chipped and appears to be maybe douglas fir or some other firewood type.
Surely ebony or iroko or even plain walnut or oak would have been better choice.
water bug
Re: An FVP in USA
Post by water bug »
I have tried John - SOS and E-Bay for the short villiers throttle cables. They do not have them. can anyone supply , or suggest a source?
What should the short length be? Thank you
Grumpy, What is a cross beam on a trolly?? Maybe this was a mis post to another thread??? WB
Re: An FVP in USA
Jeremy should be able to give you the answer to length, then modify your existing one.
