fuel tap
Silver Surfer
Re: fuel tap
Once you've got the little screw out of the side, try squirting a little WD-40 down the screw hole. Wait a while, and if it still doesn't budge, just pull harder, as you'll probably need a new cork anyway, if it's sticking that badly.
Re: fuel tap
Put a cup full of fuel mix in the tank tighten the cap & air vent, lean it over so the fuel tap is under fuel & leave it out in the sun for a couple of days.
Re: fuel tap
Heat it up over the gas stove while holding the fuel tap with a pair of pliers. 20 seconds should be more than enough to get things moving again and before it gets too hot to handle.
I've done this countless times before with old plungers, and it works well enough although nowhere as good as replacing the cork altogether. That little screw can be a bugger and DON'T LOSE IT otherwise you'll be cursing
The rest is fairly straightforward once you've got the plunger removed from the tap body.
Happy boiling
Happy boiling
Re: fuel tap
Or buy a Seagull fuel tap repair kit from John Williams, & you'll get a new cork & a new screw!
Re: fuel tap
g'day guys, i did the wd40 thing and left a couple of hours and it was still very solid but i gently but firmly wriggled and pulled and it came out and it was ok so i did the boiling trick and it was too big to go back in so i oiled and greased it and left it a while and got it back in and works fine, so thanks everyone for your input, much appreciated, peter
