Coil question
Coil question
Will a mk3 Wipac coil replace a mk2 Wipac?
Re: Coil question
Yes if you change the base plate, CDI, flywheel, starter cup/spacer & flywheel nut & washer, you basically need to change the complete ignition/starter system.
Re: Coil question
But a mk3 coil won't directly replace a mk2 Coil?
Re: Coil question
List of magnetos:
JM coolie hat villiers coil with points
Mk1 villiers coil with points
Mk2 wipac coil with points
Mk3 CDI
Mk4 CDi
Mk3 CDI
Mk4 CDi
- fleetingcontact
Re: Coil question
Hi Lodgey
You see, Charles thinks his reply is witty and amusing. You'll get used to this sort of thing if you stick around long enough.
No, you can not substitute a mk3 coil for a mk2. You cannot, to the best of my knowledge, swap any parts from one ignition system to another with the possible exception of perhaps the 'coolie' hat and the mk1 but to be honest I don't know for sure.
You can replace an entire system with another. Many older engines now sport a system that they were not originally fitted with. Any one you like.
In my humble opinion, mk4 cdi units are far more available than the mk3. So go with that if you want breakerless. But one glance at ebay will tell you that you can find a mk2 replacement coil anytime. The rest you'll have to be more patient.
Re: Coil question
Thank you MrFleeting,an answer that I can understand,thanks
Lodgey.
Lodgey.
Re: Coil question
No it will not fit.lodgey62 wrote:Will a mk3 Wipac coil replace a mk2 Wipac?
But it will fit if you (as Charles correctly said without any waffle) "Yes if you change the base plate, CDI, flywheel, starter cup/spacer & flywheel nut & washer, you basically need to change the complete ignition/starter system."
"Charles thinks his reply is witty and amusing. You'll get used to this sort of thing if you stick around long enough"
Strange comment I would say.
Re: Coil question
It wasn't meant to be a witty answer, just 100% accurate, my role as a moderator is to ensure accuracy, many people upgrade their ignitions to CDI's especially the guys that race Seagulls!
Re: Coil question
Perfectly sensible answer and good advice, if you want to fit a later coil unit all the parts need to be changed. As a set. It is what it is.
