Anzani
Re: Anzani
You never said which tank model your after, Cookie.
Re: Anzani
Sorry I should have said its the later model super single , square ish tank , not the round one
Re: Anzani
Cookie give me a ring I might be able to help between 9am & midnight.
Re: Anzani
Re: Anzani
I have a complete power head inc. the tank with a full set of water slide decals in very good condition, only missing the Zenith carb fuel pipe, it looks so good It would be rude to break it.
If you ever get down to this end of the world your welcome to have a look Cookie.
It's time I started clearing some room.
Re: Anzani
Thanks Charles , I will message you
Re: Anzani
Only problem with those decals is that the letters are not individually cut, therefore you have this blue background that may or may not blend with the finish color on the tank. They are otherwise a good reproduction.Collector Inspector wrote: ↑Wed Nov 06, 2019 9:21 am These work well
https://www.ebay.com.au/itm/British-Anz ... SwawBanqGt
