sd 102 restoration. where do I start ?
skyetoyman
Re: sd 102 restoration. where do I start ?
Post by skyetoyman »
Carb cylinder not head . Still rubbing - only one worn out finger so far. As the actress said to the bishop
Whoops, Sorry.
woodbutchergraham
Post by woodbutchergraham »
You need what is called in the trade as a frigging stick. A piece of dowel with a slot part down its lenth and wrapped in wet and dry. This saves a sore finger and gives an even finish
skyetoyman
Thanks for that one , Graham. Worked a treat. Turned down a shade on an old unimat lathe from a brush steel (wooden broom handle) . Changed my slightly oval hand rubbing into a smooth round bore
woodbutchergraham
Pleasure to help Terry some of the old tools work a treat when fettling. Im sure theres loads of other improvised tools out there that just need reserecting :P
skyetoyman
Gave it a twenty minute run yesterday in the barrel. Slipping into gear but I can sort that by turning the clamp. Still leaking fuel from the two holes in the carb float chamber.
Is there a setting for float/needle ? Or is it just trial and error ? Maybe I need a new needle
woodbutchergraham
Terry i slid the float down the needle a tad it stoped the leaking problem i had and still allowed fuel to flow give it a try. (1 tad = 2mm 2 tads = to much)
give it a try not guaranteed but it worked for me !
Decided to get my SD out for a good run up, before putting away until the spring. Also fitted the brass inlet trumpet :P
Started first pull, and seemed much sweeter, suspect the new inlet helps. Heres a video:
http://www.youtube.com/watch?v=quccREu9 ... e=youtu.be
skyetoyman
Love the sound of the 102's and it smokes just as much as mine but then it is old enough to smoke.
Brilliant job. Little differences -- mine does not have a copper fuel pipe or a brass tiller arm
Any results from those doing thread repairs/inserts on the amal carb
The brass tiller arm is actually incorrect. It should be steel, painted black. I have one, but have not got around to cleaning it up and painting it. I agree the 102 is my favourate seagull, when all is running well it will tick over slowly and you can feel the kick of each firing stroke :P
Regarding the thread repairs, a mate with a lathe has agreed to make me a couple of banjo bolts with a UNF thread. Once they are made it is just a matter of fitting a UNF helicoil to the carb body :P
I have a SD carb to repair, and yours will be number 2.
I believe John is in the process of collecting a batch of these faulty throttle bodys so that they can be re sleeved & then sold on an exchange basis, without the need for a new banjo bolt.
For a location that has little or no access to oxygen as it's always covered with two-stroke oil & petrol, the corrosion can only be galvanic, adding a third or forth metal to the mixing pot might well increase the problem.
skyetoyman
Next project was going to be full restoration of WSPCL . Sadly the amal 2 jet looks in worse condition than the one on my old SD.
I may use the good bits to build one good one and fit an amal 416 to the Century. I assume that is not a problem ?
badly filled throttle body - cable entry messed with
Will check thread on throttle body , refill body with ? and respray
skyetoyman
Perfect fit ... sadly weather not been nice enough for a short run
Won't be on the sea though... ACR will be soon.
John_84
Post by John_84 »
I'm in the process of fixing up an old SD myself
Can anyone tell me if the float bowl should be on the left or right hand side of the carb - or if it even matters?
This is Lucy - she rules the waves no more
The general consensus is that the bowl is closer to the tank.
Nice brass carb. I thought they only came with the later SD's so is good to see one on an early SD. Niander is after one of those.... :D
