The you tube display is not coming up on the posts I'm reading ie Pizey's 'My seagull on the water'. I've checked the control panel and help and at a loss. Any ideas??
Have you tried... Tools/Internet Options/Security/Reset all zones to default level...? (the Internet Zone should be Medium-High)... might work, I have IE 8.0 and Skype!
Let me have a think and I'll get back to you... what do you actually see in the forum... a space where the video should be or do you see the video but it won't start?
Yep, and now I can see Pizey's one too. Haven't changed any setting nor has the puta been turned on or off since last post to you! Did you change anything your end?
Can you just check one more time... I did something at this end, but it shouldn't have affected Pizey's post, so I have undone my change for now. If you can still see the video's then it must have been your IE settings, if you can't see them again, then I can put my change back in.
