I have done everything possible now:
-Cleaned tap filter
-Cleaned fuel line
-Cleaned carb with carb cleaner
-Cleaned filter behind banjo
-Checked float operation; all good when float in the down position a steady trickle of fuel comes out
-Checked fuel needle valve does not stick
-Checked main jet
-Check fuel needle is clean
and still it will only operate ok on choke, but not without (ie running lean)
I have run out of ideas now, what next?
