Re: weakest safe mix
Posted: Sat Apr 14, 2012 7:23 am
Ran my gull today after fitting an NGK plug and it seems to run markedly better than on the Champion. Smoother, no flat spot and much happier.
Saving Old Seagulls Owners Forums
https://saving-old-seagulls.co.uk/phpbb3/
https://saving-old-seagulls.co.uk/phpbb3/viewtopic.php?t=3330
It was on this basis (and the scarcity of EP140), that I suggested, and am trying a mixture of engine oil and grease for the gearbox. This gives a homogenous thick mixture, that will form an emulsion (I know this from my dunked trailer wheel bearings!), especially with the dispersants in the engine oil. You still have the advantage of a thick fluid that'll stay in the gearbox. Unfortunately, while I now have it in my gearboxes, I don't actually use the Seagulls on the boat, so I can't comment on its effectiveness in practice.Rex NZ wrote: The manufacturers reccomendations were made with the best knowledge & materials of the day, but, that era that has long been surpassed, (along with whale oil, acetylene welding & egg beater drills). Oil technology has advanced hugely including, the use of dispersants & friction modifiers. Unlike gear oils, modern engine lube oils contain dispersants & emulsifiers. These give the oil better ability to suspend leakage water as a relatively harmless homogenized solution. Without dispersants the water has more tendency over time to separate out from the emulsion. So given all this, I use a thinner oil such as ordinary modern engine lube oil SAE 10w40. Note that thin oil also tends to leak out faster & leak water in faster, this is especially the case in worn gearcases. Important you change it after every outing.
Rex NZ
