Re: Loose bushes in crankcase
Posted: Fri May 25, 2012 12:01 am
I think we're missing the point here, main bearings do not spin when they're new, so spinning must be caused by worn bearings, running dry & grabbing the crankshaft, there is enough energy stored in the flywheel at 4000 revs, & assisted by a running engine to spin 1 or 2 bearings.
How did you measure the ID of the main bearings Art as 2 thou doesn't sound excessive, are you confident in your measurements?
If your using a T bar take 3 readings 120 degrees apart to check for ovality.
There is no point putting tired bearings back in an outboard you plan to use!
