Sea bee minor
Re: Sea bee minor
If you are going to repaint, its not gold, its a 50 50 mix if hammered gold and bronze, the recoil parts on top of the flywheel have a habit of breaking, I still have an engine cover with tank and some other parts off a dead Mk3.
robhc1000
Re: Sea bee minor
Post by robhc1000 »
Keith.P wrote:If you are going to repaint, its not gold, its a 50 50 mix if hammered gold and bronze, the recoil parts on top of the flywheel have a habit of breaking, I still have an engine cover with tank and some other parts off a dead Mk3.
I will try to clean up bronze area first, it does not look to bad, the tank and cowling are the worst and i believe the colour is old english white?
jonmac
Re: Sea bee minor
Post by jonmac »
Hi Keith, Would the Seachief's have been painted a similar color? I had to source another cowling and recoil starter from New Zealand, and the color on that cowling was a turqouise color. Any ideas?? . . . jonmac :?: :?:
Re: Sea bee minor
I couldn't say what colour it should be, but I did spot this, it looks more like your one.
http://www.ebay.co.uk/itm/Old-Sea-Bee-o ... true&rt=nc
jonmac
Re: Sea bee minor
Post by jonmac »
Thanks Keith . . . jonmac :D
robhc1000
Re: Sea bee minor - a set back.
Post by robhc1000 »
Work on engine suffered a setback today, the prop does not want to come off, the nut undid fine and have tried soaking with oil, tried hot water as well. Was gently tapping prop with wood and hammer and it broke a large piece off - bugger!
Any ideas how to get off and where to get a new prop please??
Re: Sea bee minor
Post by Stelios_Rjk »
Is this your prop 380557882907 ? (Search that number on ebay)
Heat on the prop, quenching in diesel and again and again. Don't be gentle with the heat on the prop. Just take care of the prop shaft that it won't change color from the heat.
Then use two pieces of wood like bricks. Lye the prop on them and hit with a hammer the shaft. That may destroy the first thread of it. You will need the appropriate die to fix the threads or put a piece of wood etc between the shaft and the hammer.
Oh, and when hitting the prop should be hot, not as hot as before quenching but hotter than after quenching.
I hope this helps.
robhc1000
Re: Sea bee minor
Post by robhc1000 »
I will give that a try, yes it looks the same prop on ebay, many thanks.
Also can a damaged prop be repaired or once its had pieces broken off are they off to the bin?
Re: Sea bee minor
I hope to see it coming off :)
Not sure about the prop..
Re: Sea bee minor
Does this prop have a cushion hub?
If the answer is yes, heat might not be the best cure!
robhc1000
Re: Sea bee minor
Post by robhc1000 »
Charles uk wrote:Does this prop have a cushion hub?
Going to sound dense now but what is a cushion hub?
Re: Sea bee minor
A cushion hub is a rubber shock absorbing damper between the prop bush that grips the shear pin & the rest of the prop, & performs a similar funtion to the Seagull prop spring.
Re: Sea bee minor
If its anything like the seabee mk3, then its just a shear pin.
robhc1000
Re: Sea bee minor
Post by robhc1000 »
Charles uk wrote:A cushion hub is a rubber shock absorbing damper between the prop bush that grips the shear pin & the rest of the prop, & performs a similar funtion to the Seagull prop spring.
Thank you, looking at a picture of the rear of the prop it does not look like it has a cushion hub.
hansomcommon
Re: Sea bee minor
Post by hansomcommon »
There are specialist aluminium prop welders (I had the skeg rewelded on my Brittania) but the cost will far outweigh the value of the engine, Ebay is the answer.
