sd 102 restoration. where do I start ?
Re: sd 102 restoration. where do I start ?
That's cheap, they take a lot longer than 95p to make.
I did manage to locate some similar screws but non with a pallister head.
- skyetoyman
Just started on Amal 2 jet . Jets are marked 02 & 09. Is this correct
The main jet is marked 40, 45 or 50 & I can't remember what the other is, are you reading them upside down?
40 = 25:1
45 = 10:1
50 = 10:1 perhaps cold climate.
40 = 25:1
45 = 10:1
- skyetoyman
Ooops ...... 50 & 30.
That's made my day
Best view of one of the new 102 transfers I have seen Terry, nice restoration!
SOS
SOS
- skyetoyman
Starting to think about putting everything back together. Driveshaft is in really good condition but does it need a finish ?
You could paint it Terry or smother it in waterproof grease! Either works!
SOS
SOS
- skyetoyman
all now going back together again. Much trouble and mess filling gearbox with 140 oil . Eventually removed oil nipple and filled with small pump oil can.
Drive tube giving problems - had to drive out again and scrape some paint off .
I have fitted new nipples to all the gearboxes I have rebuilt so far. You can then put SAE140 in a cheap new grease gun and jobs a good 'un.
I have some nipples if you want a few. There also plenty on the bay. BSP thread,
Have you come across any black ones?
Cheers....
Cheers....
Avoid the Zinc plated ones, the zinc lasts seconds!
- skyetoyman
just read an old post by Oyster 49 that said the thread was 1/4 BSF plus one today that said BSP
Help ?
Help ?
1/4 BSF
All this talk of nipples is getting my SFs and SPs mixed up..
H-A is of course correct as was the earlier post.
