Page 4 of 4
Re: OA Longshaft
Posted: Fri Dec 07, 2012 8:23 pm
by Stelios_Rjk
Oh my God!! And I thought that I have done a nice restoration to my outboard. Now I have second thoughts..!
The best job I have ever seen!
Re: OA Longshaft
Posted: Fri Dec 07, 2012 9:48 pm
by Niander101
Of course its superb ...love those top feeding Amals
is the choke inlet type original?
only other thing im wondering about is the throttle type?
brilliant job!
i want one!
youtube vid?
Re: OA Longshaft
Posted: Fri Dec 07, 2012 9:50 pm
by Niander101
stelios you will have your chance with the SD mate
Re: OA Longshaft
Posted: Fri Dec 07, 2012 11:09 pm
by david1230
Remarkable work! Really lovely...and definitely raising the bar for restorers. Wish we could see it in person and listen to it purr. Can't wait to see and hear on YouTube on my Bose speakers!
Re: OA Longshaft
Posted: Wed Dec 12, 2012 9:09 am
Excellent work here!
I suppose that the gearbox bushes have been checked as well as the crank shaft big end play? Is there locking wire on the big end cap fasteners?
Thought to ask as it is an OLD motor and no interior components have been laid bare during this post having been checked before running. The stellite treated ends of the gudgeon pin should be inspected as well.(MOST IMPORTANT)
A nice cosmetic motor may well run but once if attention is not applied to mechanical basics.
Call it "Attention to Detail"
Heads Up is all
Once again, well done!
PS: Top feed bowl?.............Check the flow rate thru the holes in the fitting
Re: OA Longshaft
Posted: Thu Dec 13, 2012 12:36 pm
by markhld
When I had the whole thing in bits & pieces before I sent off to the plating shop, Charles L came down to do a survey, as there are very few long shaft OA's in existence & he wanted to see if there was any difference between mine & a standard shaft series 3 OA.
None of my gudgeon pins have stellite ends, all are just aluminium.
He said the motor was in very good, looked like low use condition, with a spark you could weld with,
everything seemed to have the correct material nuts, studds & bolts, & the gearbox had some of the best original bearings he'd ever seen.
He said it looked like it had been hardly used & just left in a damp barn for more than 60 years.
The only new bit I thought it needed was the exhaust to gearbox chrome tube & he gave me a new tiller arm to cut to length as a replacement, but when I replated the old one it came up perfect so I used that.
Re: OA Longshaft
Posted: Thu Dec 13, 2012 12:47 pm
by Niander101
Would be nice to see it running if possible
Re: OA Longshaft
Posted: Thu Dec 13, 2012 1:22 pm
by markhld
I will show her running when the weather get better and if i can find a clean freshwater river to try her out on back of my boat, I have no fear of her running at all. She will run like a dream, I have had her running already
It's the best OA i've got.
Re: OA Longshaft
Posted: Thu Dec 13, 2012 3:48 pm
by Niander101
Fresh water river sounds good for it.
roll on spring then!
Re: OA Longshaft
Posted: Thu Dec 13, 2012 8:47 pm
Looks good Mark.
We could do a spring Thames run, bring out the SDs or earlier motors.
Same old Cholsey formula, down to Seagull for a coffee, then up for a pub lunch and back.
Perhaps oyster will get his SD out.
Re: OA Longshaft
Posted: Fri Dec 14, 2012 10:23 am
Good idea H-A.
It's about time we had a load of restored engines in the same place at once. How cool would that be
Re: OA Longshaft
Posted: Fri Dec 14, 2012 1:15 pm
A load of restored engines sounds good. Last time I saw that was at Ibsley in 2010...
Re: OA Longshaft
Posted: Fri Dec 14, 2012 8:02 pm
by Niander101
I have this ON in my possession now its coming apart ok and thankfully was not seized up!
Re: OA Longshaft
Posted: Sun Dec 16, 2012 1:08 pm
markhld wrote:When I had the whole thing in bits & pieces before I sent off to the plating shop, Charles L came down to do a survey, as there are very few long shaft OA's in existence & he wanted to see if there was any difference between mine & a standard shaft series 3 OA.
Err, maybe check the pin ends again? I may well be wrong but Aluminium? Floating pins always had Stellite?
If you see aluminium that may not be correct.
Just my thort here.
Stellite falls "OFF" with age.
Stellite stops the Aluminium stop ends from wearing out...............google it if you like.
Charles would know the difference I am sure so correct me if I am wrong eh?
My OA and other Old Motors have Stellite coatings..........It is obvious when looking at it, yes, the item most times is an Aluminium base metal that looks really good when Stellite Flaked away..
If you are happy with your internals, run your motor and enjoy sights, sounds and smells like we do.
YouTube Vid?
