Page 4 of 8
Re: 40 minus Restoration
Posted: Tue Jan 08, 2013 1:46 am
by Niander101
Youll know when you get a villiers carb and the other end is the same tap fitting
ill have 2 of those pipes off you but ill send the dimensions as i have my floatbowls on the other side
Posted: Tue Jan 08, 2013 10:46 am
FVP nickle Tube for Villiers for me
Posted: Tue Jan 08, 2013 11:21 am
I'm fairly sure that no Centuries ever left the factory with copper fuel pipes, plated or otherwise. SD and SN models did, and here's a photo of what it looked like.
The F, FV, FVP, LS and LM had plated pipes, either a plain 'U' shape or one with a curled section. These have all appeared on here fairly recently, so please forgive me if I rush off out to lunch rather than dig 'em out immediately. The elderly father in law is in town this week, and I'm what a good firefighter friend of mine calls 'smothered in petticoats' as a selection of family females is clucking and twittering getting ready for what anyone would think was a royal wedding or a coronation. Me (and I suspect Father-in Law too) are just going out for a steak and a beer.
I'll dig others out later if required. Maybe it would be a good idea to get the different types on one page.
Posted: Tue Jan 08, 2013 9:10 pm
A few pics whilst Charles lets his steak go down..
Note the correct end fittings are soldered on ferrules which the nut then screws into the fuel tap or float bowl.
Threads are: Amal float bowl 1/4 BSP, fuel tap 7/16 x 19. For the villiers carb the banjo fitting must be drilled and the pipe soldered in place. There are some nice brass banjo fittings around..
Posted: Tue Jan 08, 2013 9:19 pm
Excellent, Oyster. Saved me a 'ferret through the files' session!
Posted: Tue Jan 08, 2013 9:39 pm
Good pictures Oyster.
I have bent copper pipe easily if filled with fine dry sand (kiln dried block paving sand is good) anneal first and crimp the ends.
Also have been told that if you fill the pipe with water, then freeze it that works as well.
Charles L was saying that it is hard to find 39/64" brass hex, 5/8" is only 16 thou oversize so would be hard to spot as being the wrong size, so may be a good place to start.
The male solder on nipple ends are readily available and easy to make, but I could not find nuts the correct shape, I made some last time made a pipe.
Can't remember the thread sizes.
Posted: Wed Jan 09, 2013 12:06 am
by Stelios_Rjk
Yeap, the correct nuts is difficult to obtain.
1/4" BSP? If I measure the threading of the float bowl it is around 1/2". What's going on? The only thing I am sure is that it is 19TPI.
About fuel tap nut I had realized after measuring that it is 7/16x19.
Posted: Wed Jan 09, 2013 12:21 am
Posted: Wed Jan 09, 2013 12:29 am
by Stelios_Rjk
Thanks! They say 1/4" but it is referred to the pipe not the threads.. Messy.
Posted: Wed Jan 09, 2013 12:33 am
by skyetoyman
Stelios_Rjk wrote:Thanks! They say 1/4" but it is referred to the pipe not the threads.. Messy.
We are british you know.
Posted: Wed Jan 09, 2013 12:34 am
by Stelios_Rjk
Posted: Wed Jan 09, 2013 4:22 am
by Chilli Dog
Dyslectic , inbred and eccentric and that's just the ones we like ~ yeah we know your British ,but we will talk with you any way
Posted: Wed Jan 09, 2013 8:11 am
Chilli Dog wrote:Dyslectic , inbred and eccentric and that's just the ones we like ~ yeah we know your British ,but we will talk with you any way
Most of them can not stop talking aye?
Posted: Wed Jan 09, 2013 8:31 am
by Chilli Dog
I can't shut them up . can you ? lol
Posted: Fri Jan 11, 2013 7:18 pm
One SD fuel tube, correctly shaped, just needs a polish and then soldering up. Quite pleased with my first try at pipe bending
I need to shop around for the bits a bit more before stocking up. The ones that go at the float bowl end were cheap enough, but the tap end ferrule and nut were £4 each
