OA 262 Gearbox
Re: OA 262 Gearbox
The funny thing is that I have three early series 1 OA's all with bottom feed, straight out, unpainted alloy float chambers. I am yet to see a brass bottom feed straight out version. The adverts of the time definitely show a bottom feed but on the later OA's I have (613 & 614) the carb has the swan neck brass chamber. The problem is that any of this could have been changed at some time or other, I have enough of them to build up a picture but it may not be an accurate one.
Rene
Re: OA 262 Gearbox
Thank you Rene.
I found another number on the carb body by the way just now as it was upside down.
# LF8205
B[/color]
Re: OA 262 Gearbox
Rene thanks.
Your post 100% agrees with my researches & I have inspected about 90% of all the known examples over the last 15 years, this carb was only used on the series 1 OA (46/032 throttle body with 22-025 float chamber) the one I've just looked at has 15 & 35 jets & a number LF 5195.
Though the gentleman who supplied Bruce's was famous for reassembling things "his way".
Re: OA 262 Gearbox
Post by Adrian Dale »
OA 3 106 has carb # 46/052. need to remove it to check other numbers
I am presuming this is original but who can tell, it may have been replaced at some time in the past.
Re: OA 262 Gearbox
I am guessing that there was a + 0.020" piston available based on what my deeds to date getting my Old Dear Fettled.
Re: OA 262 Gearbox
Hi all
I am revisiting the old dear as of now...
I will start another topic/thread shortly.
Also looking at my FVs as I have been sourcing bits for them for ages.
Anyhoo
Re: OA 262 Gearbox
Looking forward to seeing the f v.s Bruce.... :mrgreen:
Re: OA 262 Gearbox
Aye!
