Britannia
Re: Britannia
No, I don't generally. I find that a bit of oily 2 stroke mix slopped about generally works!
pegasus*1760
Re: Britannia
Post by pegasus*1760 »
i have had my mariner running for a while now and have noticed that it smokes quite a lot, is there anything i can do to rectify this. is it a case of replacing the piston rings or will it involve a rebore, as i intend to put it back into service at some point in the future i want to be as enviromentaly friendly as possible and not upset the neighbours. what would you suggest . :?:
Re: Britannia
pegasus*1760 wrote:Thanks for the info. do you seal the tank with anything afterwards to prevent the rust from re accuring ?
Once rust is removed no other treatment would normally be required more than draining and dry storage as normal. Leave the fuel cap off so no condensation etc.
skyetoyman
Re: Britannia
Post by skyetoyman »
Move next to Stelios
Re: Britannia
Must be room on the balcony left?
Re: Britannia
Post by Stelios_Rjk »
:lol: :lol: :lol: :lol: :lol:
Sure!! The tenants on the ground floor will leave during Summer so the garden is waiting for you.. room for your Seagulls and trained neighbors. They may complain if you run a motor without the exhaust..!
And you could always use my test bin on the balcony :D
pegasus*1760
Re: Britannia
cheers. :lol:
Re: Britannia
Your Britannia is lubricated on a total loss system i,e, pre mixed fuel.
Smoke is a given for 2-strokes, when it stops smoking, start worrying.
Re: Britannia
"Smoke is a given for 2-strokes, when it stops smoking, start worrying."
YEP!
pegasus*1760
Re: Britannia
I found myself with some spare time on my hands this weekend so i decided to have a go at making a silencer for the mariner out of brass sheeting.what do you think , to big. :oops:
mariner silencer
mariner silencer
mariner silencer
mariner silencer
htc2 221.jpg (18.63 KiB) Viewed 3974 times
mariner silencer
mariner silencer
htc2 219.jpg (23.11 KiB) Viewed 3974 times
mariner silencer
mariner silencer
htc2 233.jpg (22.52 KiB) Viewed 3974 times
pegasus*1760
Re: Britannia
a few more photos in daylight, :D
Re: Britannia
That's a nice job? Ever considered making seagull tanks? :)
david doyle
Re: Britannia
Post by david doyle »
Jeeze you brits make north americans look like school children when it comes to fabrication.
pegasus*1760
Re: Britannia
Hi Dave,thanks for the comment but it was not my intension to belittle anyone, my father was a toolmaker by trade and his hobby was building model steam engines and when he passed 2 years ago he left my brother and i the contents of his workshop , i got his lathe and a milling machine and my brother got the rest being the oldest son. i also recieved a sheet metal roller for the bench top which i have never used before but this weekend i decided to have a go at rolling sheet brass ,i then turned up some end blanks on the lathe and what you see in the photos is the end product i am very pleased with the end result as it is my first attempt at fabrication . regards steve
pegasus*1760
Re: Britannia
Hi, does anyone know the prop size for the swordfish and the mariner, are they the same size !. the mariner sits on a reduction gearbox of 2:1 is the swordfish geared the same.
