Keith,
That looks very smart indeed. Even the choke has the 'pin' retained in place. Is that quite rare?
The aluminium support bracket (I wish I knew the correct name) is the early type that fits around the lower crankcase.
I believe, Keith, that you have the crankcase of a much later one. I would be interested what kind of aluminium support bracket that had.
FVP10021
Re: FVP10021
First off, well done Stelios, for a very nicely turned out motor, still one of my favourite motor, other than that other model I can not afford.
As far as this motor goes, its all original, I just replaced the tiller, the engine has never been apart.
If they don't have one fitted, I normally make one.Even the choke has the 'pin' retained in place. Is that quite rare?
- Stelios_Rjk
