Availabe at most car part stores is bronze bush PB106...am using it to replace part 1370 ( bush above the water pump ) in my AD 1947.. fitted into a polyurethane outer ( turned in material from a boat trailer roller ) its a perfect fit
Size is internal 12.58 external 16 and length 50 mm so enough for two
sorry you brits that its a Spigot Bearing for a Holden 6 cyl manual ..but if you are desperate you can e mail me !!!!
usefull restoration bronze bush
