ARCHIMEDES-PENTA OUTBOARD MOTOR
anybody got any photos or info of a twin ?...[not sure exactly what model]
someone local has one and it looksvery old and interesting
horizontal opposed twin[but he wouldnt sell me it] .....but believe it or not i just got an short water jacket sd 102 totaly freely turning with compression off him for £2..!!!! ...what a day !
ARCHIMEDES-PENTA OUTBOARD MOTOR!
Is it definitely an Archimedes Penta? My knowlege of Archimedes is very sketchy, but Archimedes (without the Penta) go way back in outboard history) and orignally made two or three sizes of horizontal twin.
Through various takeovers (Electrolux etc.) the Archimedes name survived and I think got combined with Penta in the late '50's or early '60's, though I don't think there were any horizontal twins by this time.
I had an Archimedes for a time, whcih I recall I dated to around 1940 - I suspected it was around an 8-10HP., and was as much as I could do to lift the thing!
I did have some basic adverts for the Archimedes range - I'll see if I still have them and let you know.
Good result with the SD though eh? You'll have to let us know when it fires up! Rick
There are a few photos of old archimedes motors on www.aktersnurren.se Also came up with quite a few hits for archimedes penta on http://forums.iboats.com use the search function. You might try going to www.aomci.org and click on links, it surprising what you can come up with if you have some time. Then of course you could google archimedes penta
Magneto number is either on the flywheel rim just under the cover, or may even be stamped on the baseplate, just visible between the spokes.
On an SD it would be in the range JM 2000 to JM 12500 originally. This number only applies to those magnetos with the dished top and a four spoke flywheel. That's what an SD would have had when it was made.
The other Charles and I have been compiling a register oif the survivors.
The pics are of a "Type B-22". I have two, to make one good and one fair to middling later.
Barrels are weakness! Else very rugged!
I believe it was 20Hp.
I would love some more tune up info if any one can help.
It is bloody heavy, both to lug about and pull start for a small bloke like me..................
The blue one fires up and idles but has one cracked block, hence the other for spare bits.
C.I.
PS: Do not forget the SD magneto numbers for Charles! He is challenged in that need as we all know. Bless him.
C.I.
