Protection for a Seagull in the wild
Posted: Wed May 20, 2009 10:06 pm
Has any member been successful in attaching a sacrificial anode to their Seagull? I’ve searched the site and read that one or two have bolted a zinc onto the leg or gearcase, but I was under the impression that you also need to attach it to a negative battery terminal (at least in order for it to work effectively)?
I am considering pressing my TSEFPC into regular service this summer and hate the idea of leaving it unprotected on the outhaul almost as much as I hate the idea of lugging it back and forth to the dock. After all, it is not that long a row… My motivation is simply that I miss running it and am sure it would be happier working than sitting in the garage.
My next challenge is figuring out if a long-shaft will work on relatively low transom of an 8’ fiberglass pram. Maybe this isn’t such a great idea afterall?
Any thoughts are most welcome.
